Will this intake fit under my hood?
Old May 2, 2003 | 09:07 AM
MTCAMARO's Avatar
Car: Camaro sc
Engine: 350 cid.
From the measuring i've done,it's going to be awful close.I'm replacing the 305 aluminum intake on my engine with a Weiand action plus and i'm wondering if it's going to hit my hood.My hood is the fiberglass early 80s'stock z-28 hood with the fake vents that indent into the hood some.A holley 650 with a Edelbrock 1207 drop base aircleaner sit on there now and it seems to have an inch or so of clearance,so like i said, it looks awful close.The weiand looks higher,but the carb mounting flange is at such an angle, it just might work.Can anybody put my mind at ease?
Old May 2, 2003 | 03:39 PM
82camaro's Avatar
Car: 82 camaro SC
Depending on the size/drop of the air cleaner, it should work. I running a holley carb, weiand stealth(I think a bit taller), and a 14x3 K&N drop base. It just fits.
Old May 2, 2003 | 03:52 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Well, heres some numbers.
Stock 1984 Z28 alum. intake:
Front = 2.950" Rear = 4.300"
Weiand Action Plus #8000 & #8014:
Front = 3.750" Rear = 4.630"
Weiand Action Plus #8004:
Front = 3.500" Rear = 4.000"
They all should fit easy.
Auggie
Old May 2, 2003 | 09:36 PM
MTCAMARO's Avatar
Car: Camaro sc
Engine: 350 cid.
The intake in question was a #8004 action plus,and the aircleaner is a 3-inch drop base.The general consensis is it'll fit ,so i'm gonna go at it in the morning.You've both been very helpful. Thanks.
Old May 4, 2003 | 12:08 AM
RadarRunner's Avatar
Car: 1987 Z28
Engine: LG-4 305
Transmission: 5-speed
I just recently swapped out my intake, carb & dist/coil with aftermarket, & knew my dual snorkel would not fit.
I opted to wait until after the install to try differnet cleaners to see what would fit (just figured less hassle with returns).
Good Luck!
Old May 4, 2003 | 10:00 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
I had an Action Plus 8024 on my old 305 with a 1" spacer, Holley 1850 carb, and a Holley drop base with a 2" filter. It all fit fine.
Old May 4, 2003 | 04:19 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Hi!!
I just put a Action+ on mine a month ago - and with the same hood. No problems.
BTW...that's with the stock dual snorkle air cleaner. And yes, it made a difference in performance.
You will most likely have problems with the throttle cable bracket not lining up like it used to. I just "tweaked" (bent) mine a bit til everything lined up.
There's most likely a aftermarket bracket you could buy also- but I don't know who sells them.
Old May 5, 2003 | 05:36 PM
MTCAMARO's Avatar
Car: Camaro sc
Engine: 350 cid.
I want to thank everyone who replied.I got it installed this weekend.I did have to tinker with the throttle bracket some.After a little carb adjustment,i could feel the difference just as soon as i hit the street..Car feels much"lighter".Takes less throttle to get the car moving.I would think thats got to help mileage too.
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Wvcamaro
Sep 4, 2015 08:38 PM
bryan623
Aug 10, 2015 11:33 AM
