is it safe to remove EGR
Old May 4, 2003 | 05:24 PM
XChris1632X's Avatar
Car: 83 Z-28
Engine: LG4 305
all of my EGR and stuff have been unhooked. what is the best way to get rid of the wires. is it safe for the car.
Old May 4, 2003 | 05:35 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
If anything, it's "safer" to have it than not.
Here's something I found about the EGR and what it does. It helps prevent engine knock while cruising, PLUS it helps lower pollution. Here's why.....
The purpose of the exhaust gas recirculation process was to simply put a small, carefully metered amount of exhaust gas back into the combustion chamber. Exhaust gas has already spent its fuel, so to speak, and is considered an inert gas and will not support combustion. This precise amount of recirculated inert gas slows the burning process in the combustion chamber where NOx is produced. Slowing the burning process lowers the temperature during combustion, thereby reducing or eliminating nitrogen oxide production. This action is most needed during cruise conditions and not at idle or heavy throttle conditions. Some may still incorrectly believe that the EGR is supposed to recycle the exhaust gas - burning it twice must be enough to reduce emissions, right? Wrong.
We just said the exhaust gas won't support combustion - it's already been burned. So, the main purpose? Reduce NOx. The side benefits? Better fuel economy for one, and maybe performance as well. Consider some of the advanced strategies for EGR flow control on some of the later engine applications. The inert exhaust gas actually displaces a small amount of space in the combustion chamber, which in turn reduces a small amount of volume that the air/fuel charge occupies. This can have an effect on fuel economy, albeit slightly, if the EGR valve is malfunctioning.
Old May 4, 2003 | 06:13 PM
25THRSS's Avatar
I wouln't remove it unless you also have it removed in the chip. If you do, then go ahead and get rid of it.
Old May 5, 2003 | 10:47 AM
Car: 83 Z-28
Engine: LG4 305
everything on my car, all of that egr stuff is unpluged do to modifications that were put on the car prior to me buying it. just want to know if it is safe to just get rid of the wires that are zip tied in a roll in many places under my hood.
Old May 6, 2003 | 10:50 AM
Car: 83 Z-28
Engine: LG4 305
no one has removed EGR. Just wanting to know if it is safe to take off the extra hanging wires and which ones to take off.
Old May 6, 2003 | 11:28 AM
BTS88IROC's Avatar
Yes its safe to remove the EGR. Many many people have done it. Do a search and you will find lots of info on the subject.
Old May 7, 2003 | 10:56 AM
Car: 83 Z-28
Engine: LG4 305
did a search but i didnt find out how to remove the hanging wires. none of my EGR is functional now because it is disconnected. just want to get rid of the wires. can i just cut them off from the firewall.
Old May 7, 2003 | 01:43 PM
BTS88IROC's Avatar
The best way to do it would probably just be to wrap them in electrical tape and tuck them away somewhere. It would not be easy at all to track them back to the firewall or ecm and cut them off.
Old May 7, 2003 | 09:48 PM
Car: 83 Z-28
Engine: LG4 305
you think it could still be done clean
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Stryker412
Sep 7, 2015 09:11 AM
TheExaminer
Sep 6, 2015 11:40 PM
RyanJB
Sep 2, 2015 01:27 PM
