good and bad news..
Old May 7, 2003 | 12:31 AM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
good and bad news..
well after tracking a lifter peck forever i decided to yank the engine and see whats going on.... (see previous threads for details)
well after we got the engine out we pulled the pan and caps to find devistation.......
the bearings where cut down to the copper like a ring around it, but the other part of certain bearings where fine.... we started to examine the throws and mains on the crank and found little burrs in the oiling holes that scat didn't get during the maching process.....
well i contacted my company i purchased these products through and they are going to pay to have the crank turned and send me new bearings........
but i still cannot figure out why those burrs didn't come out when the crank was cleaned???? i scrubbed that sucker for a good thirty min in the tub and it still done this...... why?
please whatever you do make sure to check every little nook and cranny of the motor before assembly twice or you will end up like me, out 500 for a bottom end redo.....
Old May 7, 2003 | 05:40 AM
ede's Avatar
ede
did you check it for burrs? that would of been a good idea. if the cross drilled holes aren't chamfered it's a good idea to do it, and deburr. if they are chamfered there shouldn't be a burr to cause a problem. remember way back when you first posted this and you were told your parts weren't the best pieces to be running? it's still true.
Old May 7, 2003 | 03:52 PM
badgta's Avatar
Car: 1991 FORMULA
yep
you know ede, i wanted to give scat the benifent of a doubt, but after speaking to the scat peopl, i have to agree that they suck with a vengance! i am sorry for ever of hearing from scat period!
the burrs we found in the oiling holes where still attached inside them and where about to break off, so even a brush wouldn't have disloged them before assembly.....
i just hope that theres someone here thats in the process of buliding a motor with scat stuff and thinks about it when they start assembly, and then makes absolutley sure they check it before they assemble....... sorry about the rant and i hope that no one has to experiance this in their buildin lifetime... lesson learned!
Old May 7, 2003 | 08:28 PM
Vader's Avatar
There is something that "Just ain't right" (as my dog would say) with a Chinese crank in an SBC V-8...
Old May 8, 2003 | 12:43 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
doh.
now i'm scared to try diagnosing the ticking noise in my z28
i think it's valvetrain related.
but damn.... looks like i'll be staying away from scat next motor i do. stay away from summit's cranks, too. they're made by scat.
Old May 8, 2003 | 01:02 PM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
That's weird. I've always heard good things about Scat. Even many books I've read highly recommend them.
Oh well, I was planning to use Eagle.
Old May 8, 2003 | 03:35 PM
badgta's Avatar
Car: 1991 FORMULA
hmmmm
well, it's not so much the quality of the crank itself, but the ****ty finishing work by scat....... the problem was they didn't get some burrs in the oiling holes on the throws and mains.... they ended up breaking off and the oil drgged them right to the berings where a sort of domino effect occured.... one bearing got eat up, then the metal from that bearing went on to the next and so on........
just if ya get a scat or any crank, try your best to clean the parts througholy in every little way......... and especially the oil feed holes, and if it has burrs that will not come out, then send it back.... because 9 out of 10 times they will come out once it's running and kill the bearings.....
Old May 9, 2003 | 08:47 AM
Vader's Avatar
The Scat is probably as good (in quality) as a factory nodular crank. But you'll still want to treat it like anything else you'll assemble into your work. Like BadGTA said, check the finish, polish it yourself, look at the trim of the weights, casting flash, parting lines, etc. Check the bolt holes in the output flange, snout. Look at the keyways.
Around here, "SCAT" is what a bear leaves behind after digesting the contents of your trash cans. żI guess the Chinese lost a little in their translation?
86IROC112
Apr 9, 2016 10:20 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
db057
Aug 22, 2015 08:17 PM
InfinityShade
Aug 22, 2015 08:00 PM
