loss of power, "popping", black smoke,...please help!
Old May 8, 2003 | 04:13 PM
redberlinetta86's Avatar
I was on my way to class today when my car suddenly felt like it lost power. I stepped on the gas and nothing, just rolling along. Then I stepped on the gas harder and I hear popping coming from the exhaust with thick black smoke and no power...It seems to run normally when going slow(first gear) but when going faster it begins to POP POP POP with black smoke. I got it school...what should I do?
-Tranny fluid has been leaking some
-Plugs and wires are fairly new
-new O2 sensor
Anybody know what it could be or have this happen before?
Old May 8, 2003 | 04:45 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
try adding some injector cleaner with a full tank of gas.
Old May 8, 2003 | 07:11 PM
I guess only when engine is hot?
When I drove it home it was running fine... up until I almost got home. The commute is about 25 mins. Again when I stepped on the gas there was NO POWER whatsoever and POPPING sounds coming from the exhaust but I didn't notice as much black smoke.
Any other suggestions?
Ignition, fuel injection system, ?
Old May 8, 2003 | 07:56 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Black smoke = running rich
Popping in exhaust = after fire (fuel burning in exhaust)
I'd say you are definitely running rich... that will also be a cause of no power.
EDIT: I dont know if you are carb'd or injected... if its a carb, it probably needs a rebuild, or at least a tune-up.
Old May 8, 2003 | 08:16 PM
Fuel injected
Its fuel injected
Old May 8, 2003 | 09:54 PM
fbodyandy's Avatar
head gasket? thats my guess.
Old May 9, 2003 | 10:22 PM
Anybody else?
How about the distributer because it seems to only happen when the engine is hot (runnning for about 20 mins).
Old May 10, 2003 | 07:05 AM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
Sounds like it might be an ignition problem. Maybe the module is overheating, causing you to loose spark, or have a weak delayed spark. Check the module, cap, rotor, and plugs. Make sure you use a fair amount of that dialectric grease on the module.
theshackle
Sep 17, 2020 08:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
86White_T/A305
Aug 17, 2015 12:16 AM
squiggy2
Aug 9, 2015 09:30 PM
