Engine starting then stopping right away.
Old May 25, 2003 | 12:24 PM
Nikemx23's Avatar
My engine has been starting and then stopping 2 seconds later. Now I have either killed it or ran out of gas, because now when I turn the key it makes a repeating clicking noise and the rpm gauge bottoms out. Please help me, I have been getting a ride with my girlfriend to work!!!!!!!
Old May 25, 2003 | 12:25 PM
Nikemx23's Avatar
It is a 1983 Trans am with a carb.
Old May 25, 2003 | 01:07 PM
Vader's Avatar
Ignition switch?
Old May 25, 2003 | 01:49 PM
Vader's Avatar
You'll have to verify that the coil has power when the switch is in the RUN position as well as in the START position. I've had them fail that way.
Old May 25, 2003 | 05:54 PM
matlock's Avatar
Car: 89 GTA
You ran out of gas, plain and simple. Go get a can and get some more.
Old May 26, 2003 | 09:45 AM
Vader's Avatar
...And you should probably recharge your battery before proceeding. Your description sounds like you may have discharged it nearly completely.
Does the fuel gauge not work?
Old May 26, 2003 | 12:23 PM
Nikemx23's Avatar
Nope the Fuel gauge is one of the things that is broken. I will go get some gas and let you know what happens. I am going to enjoy my memorial day though. Work on the car will continue on tues or wed.
Old May 29, 2003 | 09:15 AM
Nikemx23's Avatar
Ok turn the key.... click click click click click click click starter or ignition switch? I am taking car classes at college next quarter!
Frozer!!!
Jan 19, 2024 04:55 PM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
92camaroJoe
Aug 13, 2015 06:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
