How often to adjust valves....
Old May 26, 2003 | 09:07 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
Just wondering on the intervals for tightening up the valvetrain when you get a new motor. I have a longblock that just hit 10k miles and I haven't pulled a valve cover yet, I figure it's time to tighten them up....I can hear them a little tiny bit, especially with the hood up.
After this adjustment, how long until the next one? 15-20k miles?
Old May 26, 2003 | 10:37 PM
Vader's Avatar
Is this a solid or hydraulic lifter cam?
Theoretically, once a hydraulic is properly adjusted, there should be no more adjustment necessary for the life of the engine, unless abnormal wear occurs, a stud pulls, etc.
Old May 26, 2003 | 10:44 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
would you trust a GM goodwrench motor to have the valves adjusted correctly factory?
Old May 27, 2003 | 05:58 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
It's hydraulic.
I have always been told that after a normal amount of time the lifters get set and then the valves should be re-tightened and set. Maybe that's wrong, but I know they are a bit loose and I know that when I pulled my vavle covers off my RS at 80k miles, they needed to be adjusted to, but that was roller, if it matters. I was told you can set them a little tighter than you would initially after a few thousand miles when break in is done for a bit more lift.
Old May 27, 2003 | 08:01 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
weird...
for some reason this post is still only showing 2 replies when there are actually 3.
Old May 27, 2003 | 09:45 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Re: weird...
someone postedabout that on the Problems board.
Old May 27, 2003 | 09:55 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
I am with Vader. If you do it right just set em and forget em.
Auggie
Old May 28, 2003 | 12:11 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
i've never adjusted the valves on my 88' roc since i got it. i finally decided to pull the covers and adjust them. yeah they were loose. some were extermely loose. after the adjustment boy the car felt way better, power wise. definite worthwhile job/repair. of course my car has 117K now compared to the 78K when i got it.
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
