to crowded
Old Jun 6, 2003 | 10:19 PM
gmracinggirl
Guest
Posts: n/a
to crowded
i think my engine is a bit crowded. does any one have any ideas. it is in my 85 z-28
File Type: bmp
Old Jun 6, 2003 | 10:26 PM
flyway190's Avatar
That 3/4" hose that goes from the driver's side exhaust manifold to the passenger side can be made longer and routed over the fan guard.
Can you email me the original pic? That one's really hard to see.
Old Jun 6, 2003 | 10:48 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
That's pretty crowded alright. I'd remove the air pump, replace the qjet with a good holley or edebrock carb and drop in an HEI distributor. That would clean up the engine compartment farily well.
Old Jun 6, 2003 | 11:09 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
yea that is kinda crowded. remove the a/c if it doesnt work, remove emmissions crap, remove computer and do what was suggested above.
Old Jun 6, 2003 | 11:10 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
i hope to have mine more cleaned up in the next few weeks or so.
Old Jun 7, 2003 | 12:26 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
I assume you don't have emissions checks in Tenn?? Or just no visual check - just the "sniffer"?
Something to think about....I got rid of a lot of my smog stuff, but I basically still run the air pump and it's piped directly to the CAT air tube. I still have the carbon canister also.
You still need to get plates every year.
Old Jun 7, 2003 | 07:10 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Originally posted by Timz2882
....... remove the a/c if it doesnt work, ..
How about this, if your car is broke buy a new one and give me the broke one.
Sounds silly doesn't it?
Fix the A/C if it doesn't work. Especially if you live in the south.
Old Jun 7, 2003 | 07:17 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Looks like somebody tore every hose and wire off of it, then put them all back without paying any attention to how they're designed to be routed. So you've got a giant blob of "steel wool" looking stuff, instead of all of that laying down in the places it's supposed to live.
Don't go ripping stuff off to make your engine compartment "look" better. A car that won't pass emissions, or that doesn't work right, or that measures its fuel consumption in gallons per mile instead of miles per gallon, doesn't "look" very good either.
A better thing to do would be to get pics from people who have the same setup (computer-controlled carb) and carefully re-route all your hoses and wires correctly using them as an example.
Old Jun 7, 2003 | 10:48 AM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
well i have ttops and there for dont need the a/c and last summer it was like 95-100+ almost everyday and i still managed with no a/c and only one power window working at the time.
and plus i dont car for the a/c in the car anyway. and plus the rubber lines where dryrotted, so i think if i had a leak in the system why spend money on the a/c which gets pretty damn expensive to replace stuff and have it either converted or repaced with r12.
Old Jun 7, 2003 | 11:58 AM
Vader's Avatar
No doubt - reroute:
IROCZ1989
Sep 4, 2015 11:54 AM
fast86z28
Sep 24, 2002 06:31 PM
QwkTrip
Feb 12, 2002 01:07 PM
rx7speed
Aug 31, 2001 05:01 AM
