Low oil pressure WHY!!!!
Old Jun 10, 2003 | 08:51 PM
camaroracer1992's Avatar
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
ok heres the deal i have a fresh 355 with a HV/HP oil pump in it. the motor is about a year and a half old and its finally running where it shoudl and all/ my problem is i changed the oil abotu a week ago and pulled off my oil filter and the damn thing had a rattling noise liek the insides were loose (FRAM) and so i proceeded to change the oil and the filter with the same. i ran it down the track with 3 passes on it last friday and i took it out tonight and the car only has like 10 psi at idle (1000 rpms) and when you get on it it gets to liek a maximum of about 35 psi and it takes a few seconds for it to get there. now my question is did i suck another filter and if i did would that make a motor lose that much pressure? i know my motor is fine liek i said its about a year old and i know ive never ran it low on oil or anything.
Old Jun 10, 2003 | 09:32 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
run compression tests. Sounds like you might have a broken piston/burned piston rings on one or more chambers.
Old Jun 10, 2003 | 09:40 PM
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
hmm i dont think so it idles liek a dream and all and it still has the power, also it doesnt burn any oil which a broken ring or a piston would do.
joe
Old Jun 11, 2003 | 01:51 AM
Odyssey's Avatar
About a month or so before my engine started to knock it did the exact same thing. About 10 psi at idle and a max of 30 at any RPM over that. Sounds like one or more of your bearings are shot, bleeding a lot of your pressure. Time for a rebuild! (unless of course there's something wrong with the oil filter, the bypass valve on the adapter that you screw the filter onto, or your pressure sending unit).
Old Jun 11, 2003 | 06:33 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What gauge is this measured with? If it's the stock one, try replacing the sending unit.
Old Jun 11, 2003 | 07:08 AM
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
an autometer pro comp liquid filled gauge. liek i said the engine is a fresh rebuild theres no way a bearing is shot already i think its gotta be the filter.
joe
Old Jun 11, 2003 | 07:10 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Don't bet on it.... I'd be saving for a crank kit.
Old Jun 11, 2003 | 07:22 AM
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
aww man dont tell me that i dont want to hear that.
joe
Old Jun 11, 2003 | 08:10 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Well I guess I could just lie or make up some bogus BS to tell you.... but I'd rather stick to the truth.
Old Jun 11, 2003 | 09:12 AM
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
why wouldnt my oil pressure be really low at start up then? ive herd fram filters arent that great also.
Old Jun 11, 2003 | 09:33 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Because when it's cold the oil is thick enough to hold a film in the greatly increased bearing clearances. Once it warms up and thins out, it flows through the bearings too fast for the pump to keep up.
Classic wiped-out rod bearing behavior.
You're right about the Fram filters, they are the crappiest ones out there, even worse than Wal-Mart brand or other things you'd be suspicious of. The days when they were the choice of racers for the parts they actually use, not just their sponsor decals, is long gone; they've been resting on their laurels now for about 3 decades that I know of, maybe more than that. I wouldn't put one on anything I own.
Old Jun 11, 2003 | 09:41 AM
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
yeah the filter i took off a week ago rattled and **** inside so i think this one will be the same too when i take it off tonight. if i had bearing failure and all the engine would knock and all which it doesnt. but say for instance the stuff int he filter rattled would the enigne still have that loss or not?
joe
Old Jun 11, 2003 | 11:10 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Hard to say.
Try replacing that junk with a quality filter, and see what happens. I wish you success but I don't hold out alot of hope.
Old Jun 11, 2003 | 05:49 PM
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
just dropped the oil and changed the filter, theres nothing in it and my magnetic drain plug just has a little of the fine powdery type metal on it like usual. im htinking maybe myoil pump is shot i dont know though.
Old Jun 11, 2003 | 07:52 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
no oil? Metal? The pump wouldn't shoot out metal shavings cause it has no other surface to cause friction, however, what does is bearings. Like RB so lovely stated, save up for a crank kit and time for a rebuild.
I know people who put togehter engines and didn't even get 10 miles on it before they took a crap
Old Jun 11, 2003 | 08:58 PM
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
awwww crap i so dont want to take this motor out AGAIN and rebuild it. ive had so many problems with this motor and now its runnign right and it takes a crap on me.
joe
Old Jun 12, 2003 | 04:07 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
i feel ya, when i was getting my cam in and new transmission, everything went wrong. When I finally got it going I enjoyed driving it around a lil (cause i won't drive it to work, to dirty) and i was going to my friends house n hit a bump at a slow speed and shattered my aluminium oil pan and bumped my transmission pan.
Just when I had it going good, my 350 is down again. lol, don't feel bad. Least you have your life and body to be thankful, theres people who can't even drive due to handicaps let alone have nice cars.
89GTAOz
May 16, 2020 09:31 AM
xxx3man`
Sep 23, 2015 10:37 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
