tune up needed?? (pics)
Old Jun 11, 2003 | 06:37 PM
llvll4l2c91350's Avatar
doing some checking on the cap, rotor and plugs. does this stuff look worn out already?
Old Jun 11, 2003 | 06:39 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Plug looks ok, a little lean, but still ok. Dunno about the cap though.
Old Jun 11, 2003 | 09:37 PM
just gonna end up changing it. plugs are still ok but the stupid top metal screws keeps coming loose. i already bought a set of rapid fires i'm gonna put on, and new MSD wires.
Old Jun 12, 2003 | 03:43 PM
Damon's Avatar
Make sure you have the cap seated correctly on the distributor body. The squared-off part that fits over the electrical plugs is sometimes difficult to line up correctly- there's a lip it has to sit inside of. If you don't the screws can loosen up due to the cap sitting slightly cocked.
Old Jun 12, 2003 | 04:57 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Take a flat metal file to the contacts inside the cap to get rid of any carbon tracking. Make sure to file the contacts FLAT and not at an angle. See https://www.thirdgen.org/techbb2/sho...hreadid=162251 for a big tuneup list, too.
Old Jun 12, 2003 | 05:44 PM
Vader's Avatar
If you're in a pinch, you could clean up the terminals in the cap. However, since it looks like a plain old aluminum terminal cap with nearly no flashover control, I'd trash it and find a brass terminal cap with deeper arc chutes. Get a rotor to match.
Old Jun 12, 2003 | 08:41 PM
89rocs's Avatar
Car: '89 IROC
Engine: 5.7lt 350 TPI
Transmission: Original :(
If your out to save some cash, clean it.. it'll work for you for awhile. Hey, if you got a few bucks, get a brass cap as Vader suggested.
Old Jun 12, 2003 | 10:07 PM
thanx for the replies. i got rid of the bosch plugs and put in rapid fires so i'll go ahead and just change everything. and upgrade to the brass cap.
Old Jun 12, 2003 | 10:14 PM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
good idea to change o2 sensor when doin the tuneup. unless it has been changed b4.
Old Jun 12, 2003 | 10:18 PM
already done
Old Aug 26, 2003 | 01:43 PM
abcx09t's Avatar
Car: 1987 IROC-Z; 2012 Ford Raptor
Engine: Modified 350
Brass Cap
Where can I get one and how much are they?
Scott
Old Aug 26, 2003 | 06:51 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Re: Brass Cap
Scott
Any decent auto parts store will have them. Just ask for one with brass contacts.
Some good brand names that use them are Wells, MSI, Proform.
All the speed shops will carry them. They are "de rigeur," as the French say.
Azrael91966669
25
Jun 20, 2017 04:04 AM
IROCZ1989
Jan 24, 2016 03:55 PM
355tpipickup
Aug 13, 2015 07:35 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
