Car is shaking
Old Jun 12, 2003 | 05:50 PM
myz28u's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Car is shaking
The car shakes when I drive. I've especially noticed at highway speeds around 70 it'll like stop for a second and then shake bad and then stop and then shake, etc. like every second. Usually it has a small shake all the time though and the steering wheel shakes in my hands. I have a basically whole new front end....center link, idler arm, struts, inner and outer tie rods....rear shocks and stabalizers also brand new. Front has been aligned and wheels balanced twice. I know my trans mount is bad and Im replacing it tommorow, don't think it would cause this though.....any ideas? Hard to have a pimpn' ride when it shakes you all around lol.
Old Jun 12, 2003 | 06:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You might have a broken transmission mount.
I have a van that I chased a highway-speed shaking problem for 6 years. I won't even list all the things I replaced. Turned out to be tires - including two new sets that were as bad as the ones they replaced. 16 tires had been on the thing before I had 4 that didn't shake. Repeated balancing didn't change anything - they weren't round at highway speed.
Old Jun 12, 2003 | 06:51 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Almost sounds too bad to be a driveshaft out of balance.
Old Jun 12, 2003 | 08:49 PM
89rocs's Avatar
Car: '89 IROC
Engine: 5.7lt 350 TPI
Transmission: Original :(
I know you said you had your front end balanced..
But you can also get your car speed balanced.
A normal balancing doesn't mean it will keep your car from shaking at higher speeds.
Call and check around to see who speed balances.
Old Jun 12, 2003 | 09:05 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
My bet is on the tires. I had a set of tires that the steel belts had seperated from the tires and had a bad vibration.
Old Jun 12, 2003 | 09:14 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
I agree, that was my problem after the car sat for a long time waiting for me to replace the motor. The tires flatspotted and caused vibration.
Old Jun 12, 2003 | 09:39 PM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
might wanna check your driveshaft (as said above)
aluminum ds will stop alot of the wobbling.
Old Jun 13, 2003 | 01:00 AM
myz28u's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Thanks a lot for all the tips. By the way two things, I DO have a broken tranny mount which Im replacing tommorow, hoping maybe it clears up some of it. Also, its not JUST at highway speed that it does this, it shakes all the time at all speeds. Its just that at highway speeds of say 65+ it acts more odd. It has the one second ok next second it shakes thing going on. Hoping to get a grip on what the heck is going on down there tommorow when I change trans mount. It's not a horrible undriveable thing yet...just more of a constant annoyance.
Old Jun 14, 2003 | 02:15 AM
myz28u's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
couple more things...Ive noticed the shake is coming from the rear. It only started after the shop redid all my brake pads and shoes...car also pulls to the right slightly and steering wheen stays slightly off center toward the right....any more ideas?
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
