Shifter dont lock into place?
Old Jun 19, 2003 | 09:19 AM
warrior_91's Avatar
Car: 86 T/A
Transmission: 700-R4 Auto
Whats the problem? It all started a few days ago and the shifter hasnt locked in place ever since. I dont like this and I dont feel safe driving like this cause I could accidently hit the shifter. I just hate the idea that the shifter wont LOCK into place anymore like it use to. Any ideas will be helpful. Thanks.
Old Jun 19, 2003 | 09:53 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
is this a stock shifter? they're not supposed to lock into place, that's why some liek myself opt to buy an aftermarket one like the B&M Megashifter
Old Jun 19, 2003 | 09:57 AM
TransAmTBI's Avatar
Engine: 305 TBI
Transmission: th700R4
whats do you mean escatly?? like in a certain gear?? or it doesnt go into a certain gear?
it should only lock into place meaning you have to hit the button to change gears, is when your in reverce... to wont go from reverse to park and nuetral i think... it should lock in park as well
Old Jun 19, 2003 | 11:18 AM
breathment's Avatar
i believe it locks in park, and also it is locked from going into reverse unless u push the button. (from netural to reverse.)
Old Jun 19, 2003 | 11:46 AM
warrior_91's Avatar
Car: 86 T/A
I dont have to use that button now to change gears except when I engage from Park. It does lock in PARK. Anything else, I can just move my stock shifter to any gear without pushing the button.
Old Jun 19, 2003 | 12:18 PM
TransAmTBI's Avatar
Engine: 305 TBI
that sounds normal to mee anyone else?
Old Jun 19, 2003 | 12:30 PM
fordeater454's Avatar
shifter
just put a 5 speed...or better yet a 6 speed
Old Jun 19, 2003 | 01:32 PM
pheonix305's Avatar
Car: 1986 Trans Am
Engine: built 305
Transmission: 700r-4 shift kit
thats not normal. you can knock it back from reverse to drive but can you move the gear selector forward without pressing the button. like form reverse to park or drive to reverse?
Old Jun 19, 2003 | 04:02 PM
rezinn's Avatar
My shifter (stock) locks into every gear.
Old Jun 19, 2003 | 04:38 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
Stock shifter:
P to R = Button
R to N = No Button
N to OD = No Button
OD to D = Button
D to 2 = Button
2 to 1 = No Button (on mine, but there should be a Button anytime you go down)
1 to 2 = No Button
2 to D = No Button
D to OD = No Button
OD to N = No Button
N to R = Button
R to P = Button
That is how a stock thirdgen shifter works. I've never run with a manual and hell I bolted the stock '87 camaro shifter to the floor of my S10 to go with the same 700R4.
Old Jun 19, 2003 | 07:26 PM
warrior_91's Avatar
Car: 86 T/A
Thanks for that info. That helps.
Old Jun 20, 2003 | 08:33 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
mine locks into every gear. Never heard of a auto that didnt.
But i had that problem and my cable was tore below where it connects onto the tranny in the tranny pan bolts. My advice would be to lift it in the air and have a look at the condiction of the cable, chevy cables are KNOWN for that. My brother had to replace his in both of his camaros.
If its not there, take out your center console and look at where the cable connects to the shift and the braket. I bet you one of the spots lost its connection/the cable tore.
let us know
Old Jun 20, 2003 | 09:54 PM
After using shifters in 5 thirdgens, what I posted is how it works. If yours locks into every postion, you have something different. I've used an '83 SC, '84 Z28, '85 IROC, '87 IROC, and a '90 Bird... and they all worked just like I stated.
Old Jun 20, 2003 | 11:01 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
Yea my shifter works exactly as Twilightoptics posted except you have to push the button on mine to go from 2nd to 1st. Upshifting should be no button downshifting should be button.
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
topteam54
Oct 6, 2015 12:21 AM
83 Crossfire TA
Sep 8, 2015 12:06 PM
scottmoyer
Sep 7, 2015 07:06 PM
