Heads and Cam setup
Old Jun 22, 2003 | 01:07 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Heads and Cam setup
I am looking at getting the S/R Torquer 305 heads and the CompCam XE262(218/224, .464/.470, 114LSA). Would this setup work with the stock chip? What kind of gains could I get from this setup? I was also considering changing to 1.6 rockers with this. Good idea? I don't want a nasty lope either. I want to keep a nice idle. It doesn't have to be as good as stock but I don't want it to sound like a racecar either. Do you guys have a better suggestion for heads and cam? I can get the whole setup for about $750.
Old Jun 23, 2003 | 12:56 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
ne1?
Old Jun 23, 2003 | 01:06 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I doubt that the XE262 is the best cam choice for a 305 TPI. You might even go slower than stock with that.
Look at these:
http://www.compcams.com/catalog/082_083.html
Especially the 260AH-14 (12-402-4)
1.6 rockers would help quite a bit.
Old Jun 23, 2003 | 01:39 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
That cam doesn't seem like it would be worth the trouble of changing. It's not much different than what I have now. I will probably be switching to the LT1 intake also.
Old Jun 23, 2003 | 02:12 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Details...
Old Jun 23, 2003 | 02:50 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
The cam I have now it the stock cam. (114.5 LSA, 202/206, .403/.415). I called comp and they are recommending the XR264HR(112LSA, 212/218, .488/.495). The duration still seems a little mild on the cam. The lift is good. If I used the 1.6 rockers that would put me at .521/.528 on the lift. I think the max lift on the torquer 305 heads is .560.
Old Jun 23, 2003 | 02:58 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I'm running that cam in my 305 right now, with 1.6 rockers. Runs pretty hard. That's a good choice.
Not a flat-tappet though, which the XE262 is.... yet another minor little detail.....
Old Jun 24, 2003 | 04:07 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Okay, I called Comp again and this guy gave me a different cam. What do you guys think?
12-262-14 (114 LSA, 218/224, .464/.470) He said not to use the 1.6 rockers. I have a set of 1.5 roller tips. He said they would give me a better gain than the 1.6 rocker. Anyone use this cam with any success on a 305? What would be the best intake to use with this setup. Would the 110 LSA be better or worse?
Old Jun 24, 2003 | 05:21 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
110 lsa is for carbed cars. 114 will work well with your tpi. It creates a better vacuum signal for the fi system.
Old Jun 24, 2003 | 06:36 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Would it be better to switch to the LT1 intake or just port and polish the plenum, runners, and intake?
84z96L31vortec
Aug 20, 2017 12:16 AM
beastin91rs
Oct 9, 2015 07:38 AM
gta90
Sep 15, 2015 04:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
