safe redline for LT-1
Hey guys, I am wondering what the safe redline for a 95 LT-1 motor is, it's basically stock with the exception of open long-tube headers and a Holley 750 vac. secondarys. it's in my bracket car and I don't want to push the bottom end to the point of breaking while shifting. thanks
Stock rotating assembly, stock valve train, you should be safe to 5,600 RPM ****ing. The LT4s with the same rotating assembly and improved valve train had a factory redline of 6,300 RPM.
EDIT: OOPS! My left index finger forgot to hit the "F" key. Yes, that was supposed to read "shifting".
Defecating is what the engine will do at much over 6,300 RPM, according to the factory.
thanks, I think I'll try shifting at about 5,200 to start and see how it goes.
by the way, I see all your little **** in your reply, I hope you misspelled "SHIFTING". if not--------
Car: 4
Engine: 6
Transmission: 5
VADER!!!! You nasty boy! Watch that language mister.
About 6000 RPM is all you should stretch it to, if you want it to live a long time. It's probably go to near 7000 once or twice.
If it a bunch of used stock valve springs it will cease to make meaningful power long before the bottom end is in danger, due to valve float. i.e. the car will go faster if you shift sooner. I'd be real surprised if the car's best time occurs shifting at anything above 5400 RPM or so, in which case "redline" isn't an issue.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Originally posted by RB83L69
VADER!!!!
VADER!!!!
That may be true on the 'F' and 'Y' cars, but the 'B' cars with iron heads still used the 85# @ 1.70" springs, like most other SBC on the planet. The LT4 "Hot" cammed engines used stiffer springs with a better rate and lift capability for the .525" net lifts.
88SS6SPEED
Nov 11, 2015 07:05 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
roysatikas
Sep 22, 2015 08:15 PM
