How fast will 1.6 lifters damage the valve guides?
Old Oct 5, 2000 | 08:44 PM
Get Blown ?'s Avatar
As opposed to the original 1.5s.
n/m
1989 Camaro RS LO3 WCT5
http://350.StreetRacing.org
ICQ: 61342629 AOL IM: BlackSunshineZ28
Old Oct 5, 2000 | 08:53 PM
Russ-So Cal's Avatar
I'm not sure, but if the 1.6's are designed for the engine, it shouldn't make any difference to the valve guides.
Old Oct 5, 2000 | 09:01 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The valves will be opened farther in the same amount of time at a given RPM, therefore will be moving faster. That means a higher rate of wear, particularly from the side load that is imparted as the rocker rubs across the stem tip.
So, put roller tip 1.6 rockers on, and you've basically eliminated the side load. Such rockers will actually allow your guides to last longer than the factory 1.5's.
82 Berlinetta, orig V-6 car. Rescued w/86 LG4/TH700R with all harnesses, sensors, ECM, etc. 2.73 open. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, ported heads, exhaust, paint, etc.).
57 Bel Air, my 1st car. Currently 396 .030 over, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Oct 6, 2000 | 03:11 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
I do not think 1.6 rockers will damage or wear out valve guides.
I think improper valvetrain geometry from not using correct length pushrods when changing cams and/or rocker will cause more damage or wear.
That's why you must ALWAYS check for valvetrain clearances to avoid these problems.
1989 IROC-Z, ZZ3 shortblock with some bolt-ons.
13.20 @ 108.69, 2.2 60' on "Road Hugger" radials and dead Auburn posi.
Old Oct 6, 2000 | 07:28 AM
Vader's Avatar
GB,
If the 1.6:1 rockers are equipped with roller tips, the lateral forces on the valve stems and guides should no longer be am issue. As 57 indicated, the valves will be opening a little farther than before, so unless they are clean in that area they may accellerate wear at the seals and upper end of the guides, and will certainly be travelling 6% more than they did before through the same length of guide.
Putting it all together, the reduced wear from the rollers and increased wear from the additional travel makes the whole thing a wash. If you're concerned about wear, compensate by changing to synthetic engine oil.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Oct 6, 2000 | 07:53 AM
Thanks guys for the info on 1.6 lifter wear. That helps take my paranoia away.
Old Oct 6, 2000 | 09:31 AM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Actually it's 1.6 Rocker, not lifter. I've never heard of a 1.6 lifter for an SBC.
George P. Lara
1994 Z28 LT1 T56
1984 Z28 High Output
Member: SCCA, SCFB, SC3GFB
Old Oct 6, 2000 | 10:10 AM
My bad, I still didn't have my morning coffee.
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
Cameeeero
Sep 18, 2015 04:00 PM
andy74
Sep 3, 2015 08:41 AM
z28guy134
Sep 1, 2015 11:50 PM
