Solid motor mounts
Old Oct 18, 2000 | 12:27 PM
GMI FAST's Avatar
Solid motor mounts
Any experience with these? How bad does everything shake? My new combo will probably break polyurethane mounts. Does the suspension absorb most vibes at cruising speeds?
1989 Formula, 383", DFI, Mini-Ram, S-Trim Vortech, blah, blah...
Best ET: 10.796 @ 125.8 mph
TURBO 406 PROJECT STARTED!!!
Other expensive hobby: assault weapons/shooting sports
Employed at:
Hahn Racecraft
Accel EMIC/DFI Tuning
Turbosystems & Custom EFI
Member of Midwest F-Body Association
http://www.mfba.org
Old Oct 18, 2000 | 12:35 PM
Vader's Avatar
GMF,
Another option is the poly mounts with some limiting engineered in. I've even seen an aircraft cable on the left side of the engine to limit torque stress on the mounts (formerly my '66 Chevy). It wasn't pretty, but it worked.
Most mounts have the steel limiting tabs, and some poly mounts may have the same stock design tabs while others have a steel bushing pressed through the poly and the outer mount, effectively limiting the crush on the urethane without damaging or distorting the mount.
Shop around a bit more and you should find something suitable.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Oct 18, 2000 | 04:04 PM
ede's Avatar
ede
i've used the moroso solid mounts in a camaro with no big vibration problems. i'd go with something like mr. vader said to limit the movement of the engine. i use a rod with heim ends and a bracket bolted to the frame and bolted to the head.
-=ICON MOTORSPORTS=-
Old Oct 18, 2000 | 04:37 PM
GMI FAST's Avatar
Thanks guys! I think I will run the solid mounts and also incorporate the engine anchor. I don't mind a little "rumble & shake".
Employed at:
Hahn Racecraft
http://www.mfba.org
Old Oct 18, 2000 | 04:45 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
I might be mistaken but I thought the enclosed (clamshell) design of the third gen (actually they started in the early 70s) motor mounts eliminated the possibility of a broken mount. Is the rubber mount not enclosed under the steel cover that the large bolt goes through?
Old Oct 18, 2000 | 05:20 PM
merf23's Avatar
If you run solid mounts yo dont need an anchor. Also make sure you use a rubber/poly transmount. There is enough flex in these cars that you will break the tailshaft with 3 solid mounts. The 69 Z28's came with rubber mounts and a limiting strap (as Vader described) on the right front mount.
Old Oct 19, 2000 | 09:06 PM
Vader's Avatar
Merf,
Those 7,200 RPM shifts on the old 302 were tough on the mounts and axles, eh?
Just standing next to my buddy's '68 Z hood when he wound to that RPM scared the hell out of me the first time he did it. I didn't want a cranium full of pushrods. He had no trouble with the mounts on it, either.
GMI,
Speaking of other "expensinve" hobbies, any idea where a long slide/barrel can be had for a 1911A Series VII now that Colts' has thrown in the towel? I'm hesitant to use Springfield parts.
Later,
Vader
"Make Me Bad"
Old Oct 20, 2000 | 09:23 AM
GMI FAST's Avatar
I'm very happy with my Springfield 1911. You might try www.wilsoncombat.com or Les Baer Customs...
Employed at:
Hahn Racecraft
http://www.mfba.org
Old Oct 20, 2000 | 01:13 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Lots of GN's I see have a rachet strap from the alt. to the body so the motor wont twist.
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
