C5 engine for my 84 Z28
Old Aug 6, 2003 | 03:08 PM
viperfan's Avatar
OK im looking for any info or web sites on how to put a C5 engine into my 84 camaro Z28, i would like to find a web site if there is one that shows every thing i need to do this and how to do it, one that has pics and all those kind of things.
thanks alot,
Old Aug 6, 2003 | 03:32 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
Try posting this on the "Motor Swap" board. Those guys over there know a lot of stuff. Some one might know what you need or know where to find it.
Old Aug 6, 2003 | 03:56 PM
Guest
Guest
Posts: n/a
its the same motor as the L98 but different compression it will bolt it the same as a L98 tpi 350 motor
Old Aug 6, 2003 | 04:02 PM
viperfan's Avatar
my 84 has the 305 carberated engine in it, so will i have to cahnge the fuel pump and all that stuff
Old Aug 6, 2003 | 05:09 PM
Guest
Guest
Posts: n/a
well if its carbed then you have to get the motor the TPI system and the wireing harness and the computer. then you have to drop the gas tank and swap out the pump the trans will bolt rigth up so no worries there. you goign to have to set up the VSS system a little bit different and you will most likely run into carp you didn't plan for till its to late.
Old Aug 6, 2003 | 06:35 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
C5 as in 5th generation corvette? If so, check here: http://www.speartech.com/coproj-1991ls1.html
Old Aug 6, 2003 | 06:46 PM
Guest
Guest
Posts: n/a
LOL he used a damn forklift LOL he said F**K the dumb sh*t
LOLOL
Old Aug 6, 2003 | 09:29 PM
rjmcgee's Avatar
You really need to get some facts straight before you go giving advice.
Old Aug 6, 2003 | 09:32 PM
Guest
Guest
Posts: n/a
ok fill me in then. its the L98 int he C4 vette the L98 is in the I-rocz how is it any different
Old Aug 6, 2003 | 09:40 PM
rjmcgee's Avatar
He said C5, which is like a LS1 or something. Be hard to find a 4 bbl intake for it.
Old Aug 6, 2003 | 10:16 PM
Guest
Guest
Posts: n/a
you right i'm thinking the 350TPI (that would bolt right in) as for the LS1 you have to have fun with the motor mounts.
Old Aug 6, 2003 | 10:17 PM
Guest
Guest
Posts: n/a
your not goign to find one. that only have the stock one a POS aftermakte one for the LS1
Old Aug 6, 2003 | 11:59 PM
rjmcgee's Avatar
I was kinda being a little sarcastic there.
Old Aug 7, 2003 | 01:30 AM
Enkil's Avatar
Man, you are WAY off there. heh.
L98=c4's from what, about 84-90
LT1=c4's from 90ish-97, I believe?
LS1=c5's
You'd be better off getting a "SuperSport Engine" or a "Trans Am Engine" from the ls1-based fbodies. The fact that whoever's selling it is calling it a Corvette engine most likely means they'll ask for more money just for the name of it. There are very few differences in the motors, however.. One important difference is that the 'vette LS1's used an electronic throttle linkage, or a "fly-by-wire" type of setup. No actual linkage, just electric motors. The f-body LS1's still used cable linkage.
That aside, all sorts of things have to be changed to fit the ls1 into a third-gen fbody. Engine of course, tranny from an ls1 car, driveshaft (as I believe the ls1 and lt1 trannies are different in length), frame needs to be modified, custom motor mounts, all the computer/wiring stuff, and so on. If you've got the money, knowledge and tools, I'd say go for it.
Oh yeah, the second part was meant for the person asking about the swap.
Old Aug 7, 2003 | 01:32 AM
viperfan's Avatar
well how much do you think i should be ready to pay for a C5 engine
Old Aug 7, 2003 | 01:36 AM
Enkil's Avatar
2-3 grand, probably. Talk to the guys at third gen resource (link at the top of the page), they did the swap, they'd probably answer any questions you'd have.
Old Aug 7, 2003 | 01:42 AM
91FireChicken's Avatar
Car: 91 Firebird
Transmission: A4
http://www.thirdgenresource.com has the LS1 swap into a thirdgen.. it's also a good parts source..
anyway, L98's were in vettes until 91, 92 started with LT1's and went until 96, and 97 was the LS1...
BUT ... you're MUCH better off using F-body parts for the reasons already stated, and because they fit better into our cars.. driveshaft is the same length, transmission fits perfectly, just need a new crossmember, engine needs custom motor mounts, new fuel pump, computer .. it's quite a pain in the ***... it'd be easier to just get something normal since LS1's are completely different engines... get a normal 350 block with nice heads and all that so that you can keep the same intake you have, and have no need to change the fuel pump, until more fuel is needed to power the engine.
I hope that all came out right... hehe
--edit--
oh.. the engine mounts aren't different between vettes and f body's as far as the LS1 goes.. but the transmission is quite different.. that's the main part where you would want to go with an f-body part instead... the driveshafts between the f-body and vette are different, but ALL f-bodies from 82-02 have the same length driveshaft.. umm... I think that's all I need to say...
Old Aug 7, 2003 | 06:32 AM
Guest
Guest
Posts: n/a
that link shows that you need custom motor mounts.
Old Aug 8, 2003 | 01:27 AM
Enkil's Avatar
Yes you do, the engine doesn't mount up in the same place.
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Exxon Limited
Aug 9, 2015 08:13 PM
