Intake Ques--Base and Runners?
Old Oct 24, 2000 | 06:48 PM
88 IROC BOB's Avatar
With what I have done so far what kind of gains would I see (1/4 mile) with getting an aftermarket base and some large tube runners?
I would like to do a complete rebuild with heads cam and intake but it all takes $$$ and won't be happening for quite a while.
350 TPI, 700R4(rebuilt), K&N's, MSD 6AL, Headers, Flowmaster, 160* stat, airfoil, MAF screens cut out. 13.88 @ 101.18 mph
Old Oct 25, 2000 | 07:27 PM
I am actually still deciding on going miniram or LTR's.
I'd like to stay with long tubes but my goal is mid 12's with the cam and heads.
I think it was Trax who got mid 12's with LTR's. I really liked his setup!
Old Oct 25, 2000 | 08:11 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I have a 14.2 right now with stock heads and cam and i am going with the Edelbrock base and AS&M runners. Hoping for 13's. I could probebly get 13's now with some tuning but this should get me in.
Old Oct 25, 2000 | 09:11 PM
rondubbs's Avatar
Edelbrock claims a 10hp increase with the base.
as&m are good for another 20hp,
so figure maybe .3 increase in the 1/4.
[This message has been edited by ron rizzotti (edited October 25, 2000).]
Old Oct 25, 2000 | 10:49 PM
My Slow Iroc-Z's Avatar
88 Iroc Bob...How did you get that great et with those mods? What grears you got and did you use slicks? What was the temp outside?
1989 Iroc-Z L98 Original engine-58K miles!!
SLP 1 3/4 SS headers, Hooker Areochamber catback, no cat, BBK AFPR, Hypertech 160* fan switch, ported and gasket matched plenum, TB coolant bypass, relocated MAT sensor, screenless MAF sensor, K&N filters, Accel cap and rotor, Taylor SpiroPro 8mm wires, Bosch Platinum plugs, Mobil 1 Synthetic 15W50 motor oil, and more to come...
Best ET- 14.24@96.76MPH / 2.17 60ft on street tires with the crappy B/W 2.77 gears.
Homepage currently under construction: http://www.iit.edu/~wicktho/len
Old Oct 26, 2000 | 05:14 PM
I got that time last year with the mods below. This was on street tires and the stock 3.27 gears. It was about 75* outside in Sept.
Here's some more info on that run
1.95 -- 60 ft.
8.90 -- 1/8 et
78.81 - 1/8 mph
13.88 - 1/4 et
101.18 -1/4 mph
Over the winter I ported my plenum, put on a AFPR and had my injectors cleaned but the best I could do was 13.99 @ 100.12 mph on Nitto Drag Radials.
I don't know why I didn't go quicker--needs a tuneup maybe.
I am thinking of 3.70 gears for next year and maybe a new base and runners. Hopefully this will get me back well into the 13's.
I would think if you can get your 60 ft down a bit you'll be knocking on the 13 sec door.
Old Oct 26, 2000 | 08:28 PM
Guest
Guest
Posts: n/a
How soon are you planning on this change? I should have some good info in January on a modded LTR setup, I think its going to work but I am searching for proof on paper (ie:dyno).
Old Oct 26, 2000 | 09:34 PM
Max, It won't be until well after the new year. I really do want to stay with the LTR setup. Ideally I would do cam and heads at this time too but it needs to be painted this winter too.
I figured if I did the gears and at least the intake it should put me well into the 13's.
There is a guy on the board (Traxion) who did cam/heads/intake(LTR) and some other things and went 12.58. He has since went miniram. I've got all the details on his buildup if you want them .
customblackbird
Oct 1, 2015 04:30 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Rally Smith
Sep 14, 2015 06:59 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
