Oil Pressure gauge is dropping to 0 psi at a stop!!!
Old Oct 26, 2000 | 07:57 PM
BrianB's Avatar
I just got back from driving my GTA and happened to look at the oil pressure gauge and it is dropping all the way down to 0 at a stop, when cruising it is between the 0 and 30 range. I just got the car back today from the body shop but previous to this it has never really dropped but a couple of notches below 30 and is usually pinned at 60 psi? Could this be a bad sending unit? I am praying it is!!!!! Let me know what you think. The car isn't ticking or making any unusual noises.
Old Oct 26, 2000 | 08:06 PM
ede's Avatar
ede
i'd hook up a mechanical gauge and double check it. if it reads low or none you need to look at the oil pump.
-=ICON MOTORSPORTS=-
Old Oct 29, 2000 | 08:31 AM
crazeinc's Avatar
well...with 0 oil pressure, you're car wouldn't be running, so it has to be the sending unit or possibly a bad gauge
82 Z28
350 carb'd, Edelbrock Performer RPM package (minus heads), Hooker Super Comps, Mufflex 4" offroad y-pipe, 700r4 with B&M shiftkit, '85 IROC 10 bolt rear with Richmond 4.10's & Auburn posi unit, Lakewood 50/50 drag shocks. Shooting for 3000lbs w/ driver.
The car's website
(Blown 355/TH350 buildup this winter)
AIM: Unitedhope
ICQ: 77979548
Old Oct 29, 2000 | 08:45 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Mine was doing the same thing and it turned out to be the sending unit.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old Oct 29, 2000 | 10:17 AM
JimmyS's Avatar
Car: 1989 Firebird Formula
Engine: 305TBI
Yep, id put money on it being the sending unit, Mine did the same thing, Later, Jimmy
Old Oct 29, 2000 | 10:22 AM
Cliff92Z's Avatar
Car: 1992 Z28
check your oil level also. i was low on oil so my gauge displayed a low reading. if you have plenty of oil, then i'd say its your sending unit.
Old Oct 30, 2000 | 07:38 PM
perp's Avatar
If you have a gauge you also have the fuel pump cut out if you lose all pressure. Therefor if you have no oil pressure your fuel pump wouldn't run. This leads me to believe that your sending unit to the gauge is bad. This sender is by the distributer.
See YA
Old Oct 30, 2000 | 07:57 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Perp, it depends on the engine.. oil pressure sending unit on my car is near the oil filter on the driver's side of the block...
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
