What to do next-- Gears or Intake?
What would give me the best bang for the buck. I currently have 3.27 gears and want to go to 3.70's.
I also want to put on a new intake with large tube runners. I will eventually be rebuilding with a cam and new heads but that's a couple years away.
Which would improve my 1/4 mile times the most?
I know in the long run both of these will have to be done but I want to know which will be most effective by itself.
Bob
350 TPI, 700R4(rebuilt), K&N's, MSD 6AL, Headers, Flowmaster, 160* stat, airfoil, MAF screens cut out. 13.88 @ 101.18 mph
Bob
I personally do not think the 3.70 gears on your set-up will help your et at all... maybe even hurt it. The Runners and new intake manifold would give you a reasonable jump in performance, and will enhance any further modifications you make in the future.
Have a look at my webpage in my signature for some of my experiences with tpi motors.
(Go to the set-up and results" section within the page)
good luck with your decision.
Todd
85 Vette
SR 383 Motor
11.67 @ 116
http://corvetteforum.net/c4/beach_bum/
Todd
85 Vette
SR 383 Motor
11.67 @ 116
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
My best ET performance was with 3.27 gears. I'd say go with the intake.
If you're not at the redline in 3rd gear at the end of the 1/4 mile then 3.70 gears would help however "best bang for the buck" doesn't fit the situation. It would be cheaper to find a 3.73 10 bolt and install it than putting 3.70 gears in the BW diff.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
LS6 Big Block buildup now in progress
Best results before the 383 blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car
91 454SS daily driver
95 Homebuilt Harley
Best 60 foot: 1.662
87 IROC bracket car
95 Homebuilt Harley
The powerband on an L98 is too low to really need gears, 3.27 is good enough. On the other hand, it is VERY starved for an intake..do that.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
Jesters's Page of Sick Pleasure
Florida Thirdgenners Message Board
ICON Motorsports
ICON Motorsports
Any suggestions on which base and runners to get. Edelbrock, TPIS, Arizona Speed and Marine etc. Keep in mind that my eventual goal is to run 12's with the new cam and heads down the road.
I really want to stay with LTR's so I want to get the right ones now so I won't have to change them later. Thanks!
Bob
Bob
ambainb
Apr 25, 2016 09:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
