Stupid valve locks won't come off!!!
Old Aug 18, 2003 | 11:15 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
This is my first time disassembling a set of heads. I'm gonna take everything apart to clean it all up, and then replace the 18 year old valve seals. I got to work last night on the heads, put the compressor over the first spring, tapped it gently with the back of a screwdriver when the spring was compressed, and the valve locks came out without any problems. I move on to the next valve, and I can't get the keepers off at all. I tried three more valves after that one, and I can't the keepers to separate from the retainer so I can get them out. I've tried spraying them with wd40 hoping that might help a bit, but still nothing. I read that you can actually hear when the keepers separate from the retainer by the sound it makes when you tap on them with something. I noticed the difference on the ones I've tried to remove, but they still won't come off. Is there anything I am overlooking?
Old Aug 18, 2003 | 11:39 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Re: Stupid valve locks won't come off!!!
Originally posted by 92blue
I got to work last night on the heads, put the compressor over the first spring, tapped it gently with the back of a screwdriver when the spring was compressed............but they still won't come off. Is there anything I am overlooking?
Yes. BEFORE you put on the compressor, place a block of wood under the valves to hold them in the seats (combustion chamber side), then tap the retainer with a light hammer. Don't tap the valve stem. Tap the retainer.
I guess it may take a little more than a "tap", but you get the idea.
Old Aug 19, 2003 | 12:05 AM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Take a large socket and place it over the retainer and give it a good whack or two, they should fall right out then. Just be careful not to miss the socket and hit your fingers, it just smashing a couple fingers against a stud with a big hammer.
Old Aug 19, 2003 | 12:21 AM
AJ_92RS's Avatar
I'm a stud with a big hammer.
But I'm not into that finger smashing stuff.
Sorry.
Old Aug 19, 2003 | 02:27 AM
kfoley's Avatar
Car: '85 Z28
Very funny AJ.... I about broke a finger doing that, but looking back it was pretty stupid, not to mention it was probably funny seeing me jump up and down yelling explicitives...
Old Aug 19, 2003 | 04:55 AM
ede's Avatar
ede
i have a "special tool" for head tear downs, piece of 3/4" pipe about 6" long with a pipe cap on it. place it on the retainer and hit it with a BFH and everything comes apart. takes only a few minutes to get a set of heads striped to the casting.
Old Aug 19, 2003 | 05:08 PM
kfoley's Avatar
Car: '85 Z28
That's a good idea ede, I'll have to make one of those for the next time I tear down a set of heads.
Old Aug 19, 2003 | 05:42 PM
ChevyGuy87's Avatar
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
wouldn't the spring go flying into your face if you just hit it with a hammer? or is there not enough tension on it?
Old Aug 19, 2003 | 06:06 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
what happens if you just tap on the valve stem?
Old Aug 19, 2003 | 06:29 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Tapping the valve stem won't loosen the locks, you can loosen the locks by hitting the retainer with a soft hammer and then using a compressor, but I do the same thing ede does, my tool is something I made out of a piece of 6" long 1 1/2" cold roll steel, I just drilled counter bore in the end of it. Place it over the retainer and hit it with a big dead blow hammer and it all comes right apart, works best on stock heads with light duty springs. For heavy racing springs I use a spring compressor.
Old Aug 19, 2003 | 10:58 PM
kfoley's Avatar
Car: '85 Z28
No, especially not stock springs, they hardly jump up at all. Besides the tool/socket is sititng over it so it doesn't have anywhere to go really.
1992 Trans Am
May 10, 2023 07:19 PM
deracer
Apr 11, 2016 12:04 AM
Cameeeero
Sep 18, 2015 04:00 PM
gixxer92
Sep 1, 2015 04:32 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
