Engine smoke
Old Sep 7, 2003 | 07:47 PM
TallWhiteGuy's Avatar
Car: 1990 rs, pride and joy
Engine: 305 tbi
Transmission: t-5
Engine smoke
Today i go to start my car a pretty good size puff of smoke flew past me coming from the back and i couldn't tell the color due to my sunglasses. Now what could this be? buring oil? Also i noticed that when i drive my car and shift into neutral pulling up to a light it will stay arounf 1500 rpm for a good amount of seconds then drop down to 800. Now i know this isn't normal. Is my engine crapping out?
Old Sep 7, 2003 | 09:33 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Is this a high mileage engine? Maybe you are just running rich and that smoke was excess gas. Try to see if you can get a color or maybe a smell from it...
Old Sep 8, 2003 | 12:30 PM
Engine: 305 tbi
Transmission: t-5
The engine is a 305 and has about 119,00 miles on it. I went to smell the exhuast kinda of gas rich. Also i was curious if the O2 sensor may be going bad?
Old Sep 9, 2003 | 08:36 AM
Steve89GTA's Avatar
My car did the same thing this morning - strange. I think my injectors or regulator is screwed.
Old Sep 9, 2003 | 04:12 PM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
When does it smoke? On cold startup? Or all the time when starting? Normally a puff of smoke on startu signifies valve seals leking some oil past them. Could also be rich, something to do with Coolant temp sensor could be a possibility also from what I've heard.....
Red iroc-z 305
Sep 30, 2015 05:22 PM
Fronzizzle
Aug 17, 2015 02:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
squiggy2
Aug 9, 2015 09:30 PM
