Disappointing Gas Mileage...
Old Sep 18, 2003 | 01:32 PM
sancho's Avatar
Car: '89 Chevrolet Camaro IROC-Z
Transmission: TH-700R4
Axle/Gears: B&W 2.77 Posi
This is in regards to my '89 IROC (see sig).
I'm not very experienced when it comes to gas mileage--I've just been happy to only need to fill up once a week under normal driving conditions. However, I've just recently started taking my IROC on some trips lately between College Station and Dallas.
I've calculated my mileage on this trip several times, and I keep getting about 20.5 MPG with an average speed of 75 MPH to 80 MPH.
I know that might not seem that disappointing to some of you guys running different setups. However, I'm running a "stock" L98 engine--it has been rebuilt, but it wasn't a "performance" rebuild. Plus, I've got a 2.77 rearend, which means that I'm not even pulling 2,500 RPM the whole time (according to the stock tach).
I could be wrong, but doesn't <21 MPG seem pretty sad for a mild, fuel-injected V8 with an overdrive transmission and 2.77 rearend?
Feel free to correct me if I'm wrong, but if this is bad mileage, what could be the cause?
Thanks!
Old Sep 18, 2003 | 01:39 PM
DanRS's Avatar
Car: 89 Camaro RS
Engine: LO3 305 TBI
Transmission: T5WC
TPI isn't as fuel efficient as some other injection systems... That doesn't seem bad to me, though I'm sure some other people will be able to give a better answer than that.
Old Sep 18, 2003 | 01:59 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if you cruise around at really light throttle for a short while and then lift all the way off, does the engine speed surge?
if it does, try replacing your EGR valve.... that helped me a good amount with my gas miliage... i already had the car in a great state of tune... but the valve still helped alot..
i would start with a regular tuneup, and go on from there.
Old Sep 18, 2003 | 02:52 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That's not really all that bad; TPI may not be as fuel-efficient as some of the newer control systems, but it's alot better than some others.... you're not too far off of its OE specs which IIRC were about 23 mpg.
Now if you were getting 11 mpg on the road, you'd have something to complain about.
Correctly functioning EGR will alow the maximum possible timing advance, which (along with correct misture) is where highway mileage comes from.
Old Sep 18, 2003 | 03:37 PM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
Your right on target new they claimed about 15-17 city and 20-24 hgy depending on year and exact setup so your not far off, One of the pains of living with this car in California.
Old Sep 18, 2003 | 04:22 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
just another confirmation, I have a stock L98 and get 21-23mpg on highway..
Old Sep 19, 2003 | 05:53 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
I guess this is the only time a TBI Camaro will win, in the MPG contest, I get 28-31 Mpg on the Hwy!!!
Old Sep 19, 2003 | 06:08 PM
83 Z28 HO's Avatar
Car: 83 z28
Engine: L69
Transmission: BW t-5
Wanna sell your IROC then?
Old Sep 20, 2003 | 12:58 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
hey i have tpi and net 28-29 MPG highway so no sniff here on the tpi.
Old Sep 20, 2003 | 12:50 PM
Digger's Avatar
I have a 86 L69 Iroc with 4 speed auto and 3.23s, Its TPI and I got 33 MPG with it on the highway.
Digger
Old Sep 20, 2003 | 12:54 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
lmao! yup... i got a tank of 33mpg on my road trip from dallas to charleston, SC
Old Feb 20, 2004 | 12:30 PM
Meatikis's Avatar
Car: '86 Z-28
Engine: 350 bored .030 over
10 mpg here....
Old Feb 20, 2004 | 07:10 PM
Fast305's Avatar
Car: 1983 G20 Van
Engine: 305 4bbl
Transmission: Possesed 700r4
Mileage has alot to do how hard you have your foot into it. The harder you drive your car the more gas you will use.
Old Feb 21, 2004 | 03:01 AM
nathan2003's Avatar
Car: Camaro
ha think you got it bad try this ****... 91 LO3 TBI camaro, stock rear with like 2.23 or somethin i believe, automatic with OD... i was getting 8 or so in town, 12 on highway... i mean i tried my damndest to get the best mileage i could and thats it.... i switched it all to carburetored, and believe it or not i gained gas mileage... about 15-17 on highway... go figure.. but don't feel bad for gettin that with stock setup
Old Feb 21, 2004 | 06:42 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Yeah, I got 17-18 mpg highway when I had my red bird (355 E-tec, Performer RPM, 800cfm Edelbrock carb, 3.08 rear gears)... That was with the lockup switch on the whole way!
Oh, I think your TBI was broken then..
Old Feb 21, 2004 | 08:36 AM
Vader's Avatar
If you cruised at more like 65-70 MPH you'd likely see a better number.
Old Feb 21, 2004 | 10:19 AM
SweetS10v8's Avatar
Engine: L98 & 355ci
Driving 2 miles round trip a day(w/ 5 stop signs) gets me 7.5MPG but I get 21-23MPG on the highway like I said in this post 5 months ago
Originally posted by thirdgen88
Yeah, I got 17-18 mpg highway....That was with the lockup switch on the whole way!
You make it sound like lockup hurts gas mileage, if you have a 700r4 that locks up and you dont lock it up, itll burn up quickly
Old Feb 21, 2004 | 12:59 PM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
damn... with normal driving conditions (hitting it once and a while) i get about 12 mpg in the city... im sure if i baby it i'd get 15. highway gives me about 16-17 i think but im always flying... hopefully i get better milage on my rebuild, lol
Old Feb 21, 2004 | 04:22 PM
Meatikis's Avatar
Car: '86 Z-28
my neighbor's moped gets like 80 MPG!! OMG but it only holds a gallon....but still...pretty cool
Old Feb 21, 2004 | 08:17 PM
thirdgen88's Avatar
Car: 1995 Corvette
I didn't mean to make it sound like that.. I meant for it to read as thats why I achieved such high numbers!!
Old Feb 21, 2004 | 11:03 PM
Fast305's Avatar
Car: 1983 G20 Van
Engine: 305 4bbl
A 700r4 will not burn up without lockup if it has a good cooler. I just hooked the lockup back up no my 1983 G20 van after it had been disconnected for who knows how long. Wired a 2 way switch so that it will lock off the vac switch or just locks after 2-3rd shift and stays locked. The point is I have never heard of a 700r4 burn up by not locking up unless it is on the verge of failing anyway.
Old Feb 22, 2004 | 07:14 AM
SweetS10v8's Avatar
Engine: L98 & 355ci
Old Feb 22, 2004 | 10:14 AM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
Over 60k on my previous 700r4 without lockup and a stock converter. Never worked at all. Transmission never burned fluid or slipped, or had any shifting problems at all. Problem was inside the transmission, probably lockup solenoid. Drove it until the case split 3/4 around the bell and vibration got so bad at high RPM's I was afraid it was going to fall out.
It had a LARGE aftermarket cooler and didn't use the radiator cooler at all.
The present 700r4 doesn't even have lockup in it but neither does the Vigilante converter.
Oops, I think I just inavertently helped hijack this thread. Sorry.
BTW, I got about 15 in town and 20 hwy in a '89 GMC with compeltely factory '88 TPI, (except that lockup never worked). Now I'm back in the thread!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
86maro_252
Oct 10, 2015 06:52 PM
kx3g
Sep 28, 2015 08:14 AM
reactor60
Sep 22, 2015 01:44 PM
