Service Engine Soon
Old Sep 22, 2003 | 06:49 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Axle/Gears: Borg Warner/ 2.77
Service Engine Soon
Ok i run my car for 30 minutes or so, then the rpm's start stumbling, and it wont even go faster than 5mph, and i cant gun it cause it wont go no where, and i got a code 44 master relay, so if anybody has been throgh this anything would help:hail:
Old Sep 23, 2003 | 06:51 AM
Vader's Avatar
On an '89 IROC (likely a TPI) the "44" is for a lean exhaust. I'd suggest you start by checking fuel pressure.
Old Sep 23, 2003 | 11:58 AM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Vader's right... Maybe your fuel filter is badly clogged. Does it stall?
Old Sep 23, 2003 | 12:55 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Or your fuel pump is taking a dump. It's been known to happen to these cars. But, like the other guys said, check your fuel filter first, it's cheaper.
Old Sep 23, 2003 | 05:29 PM
Nixon1's Avatar
If it's not the filter...sounds like the pump is overheating maybe. Do you run it below 1/4 tank frequently? Is the problem more pronounced with less gas in the tank?
Old Sep 23, 2003 | 05:57 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Yeah i do run with 1/4 tank at times, well most of the time, but like i changed the fuel filter, and it still did it, i changed the ignition coil, and it still does it, so now i dont know what 2 do.
Old Sep 23, 2003 | 06:01 PM
Nixon1's Avatar
Try running with close to a full tank and see if it does it. If it takes longer to happen, or doesnt happen, then your fuel pump is overheating. That's what it sounds like to me. t's an in-tank pump, so having extra gas in the tank soaks the pump and cools it. Running low on gas lets it heat up too much and burn itself out.
Old Sep 23, 2003 | 06:10 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
are there any high performance parts for this type of problem? and i also get a code 34, and i got a new maf. So what do i do to get rid of that problem?
Old Sep 23, 2003 | 06:13 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
wait i remember being at lil bit less than 3/4 a tank and it still did it, so if its not that what else could it be? my ignition?
Old Sep 23, 2003 | 06:18 PM
Nixon1's Avatar
When it starts doing it...if you can keep it running, check your spark. But it really does sound like a fuel delivery issue to me, unless you're like dumping black fumes out your tailpipes.
Old Sep 23, 2003 | 06:23 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
how about the rotor? or the fuel pressure regulator? u think it may be that? i mean i got a brand new 49,000 mile engine 350 TPI so im pretty much pissed off at my car and at myself for not finding the problem
Old Sep 23, 2003 | 08:02 PM
Vader's Avatar
Get that fuel pressure gauge connected yet? I think it might reveal a lot.
Vintageracer
Jan 10, 2020 05:33 PM
backtothe80s
Sep 5, 2015 12:39 AM
Jae992
Aug 27, 2015 09:07 AM
kyleb24
Aug 15, 2015 08:24 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
