Top End Tick
Car: 1990 RS
Engine: 3.1 MPFI
Top End Tick
I have recently started to hear a tick comming from the top end of my 3.1. After doing a search most have said either stick injectors, loose rockers, collapsed lifters, or exhaust leak. I personally don't think it's an exhaust leak because I just had one fixed and this tick sounds different.
I also seem to have a miss. Would injectors, rockers, and lifters all cause a miss. I'm try to narrow the possibilities as to what it could be.
Car: 1990 RS
Engine: 3.1 MPFI
The thing is...I just had an exhaust leak fixed. The tick that it made was very distinct. It didn't sound the same as this tick that I have now.
Car: 1990 RS
Engine: 3.1 MPFI
I have also been having some idle problems with rpms surging and stalling. I'm not sure but I wouldnt think an exhaust leak would cause that. I know injectors would but could rockers or lifters cause this also?
Car: 87 Camaro Vert
Engine: Cammed LT1
I had the same problem about a week ago untill the engine decided to die but thats another story. Is the sound coming from near the distributer under the plenum? Mine was REALLY loud, not an exhaust leak. I could hear it all the way up to about 2700 rpm untill the exhaust note drowned it out.
Car: 1990 RS
Engine: 3.1 MPFI
I know that clean injectors tick but should I be able to hear the tick with the hood closed, sitting in the driver seat with the window down?
Would loose rockers or collapsed lifters cause my car to bog down and stall?
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
Originally posted by onebinky
when the injectors are clean they are supposed to make a ticking noise.
Matt
Matt
Every car I've ever owned has made the noise before I've cleaned the injectors, and have been louder after they have been cleaned. It's the sound of the little valve inside opening and closing I think. I know it's the injectors because you can isolate the noise with a stethescope. Just my experience
Matt
Matt
Car: 1990 RS
Engine: 3.1 MPFI
Yesterday on my way to work my SES light came on. When I got to work I pulled my codes and got the usual 12 along with code 45 (oxygen sensor rich). I am hoping that this code helps eliminate some possibilities and narrow down my troubleshooting. Anyone have any ideas as to what to be looking for now?
Car: check
Engine: check
Transmission: check
The ticking may be from a spark plug wire or boot that is arching to ground.
RBob.
Car: 89 Formula 350
Engine: 409 nitrous' small block
Yes you could surge and stall out from a loose rocker or collapsed lifter, not all that likely, but it could happen. It could also cause your o2 sensor to get a false rich and trigger the ses. That cylinder could be dumping raw fuel into the exhaust, causing a false rich reading, causing the ecm to lean out the mixture, etc. I've seen it happen, but it's kind've a long shot, lot of things have to go wrong in the right way for it to happen.
First thing to do would be to get an automotive stethcope or use the old screwdriver trick to pinpoint the noise.
Car: 1990 RS
Engine: 3.1 MPFI
Okay I figured out what the wierd exhaust is. This morning I fired up my car and looked at the muffler. There was smoke (or whatever it is when it's cold out) coming from a hole in my pipe connecting the cat converter to the muffler. That should effect performance...?
Anywho, I'm going to taking my car to the garage tomorrow to have them test and clean my fuel injectors which I doubt has ever been done before. There is probably crud built up on them all since the original owner let it sit for a long time.
Even if that doesn't fix my surging problems I figure it is something that would be good to do since it's probably never been done before.
Car: 1990 RS
Engine: 3.1 MPFI
One quick question...
I suspect that my surging problem is a result of bad injector(s). When the car does surge the rpms not only bounce but the volts do too. Does this sound like a resistance problem, clogged injector, or fuel pressure regulator.
It's always done it but I never thought anything of it. I was going to have all of my injectors sent away to be cleaned at Cruzin because I thought they were clogged but now I think that maybe the resistance or something electrical with the injectors is to blame since the volts fluctuate with the rpms. What do you think?
Car: 1990 RS
Engine: 3.1 MPFI
Can someone tell me if my volts are fluctuating with the rpms because of an injector with bad resistence?
Would they fluctuate if the resistance were good and the injector(s) were clogged?
I had a surging rpm problem with my 92 firebird 3.1 After a long and exhaustive search in which I replaced my map sensor, O2 sensor, cap, rotor, plugs, wires, pick-up coil and coil. I still had the problem. While I was replacing the pick-up coil, I noticed that the round magnet on the distibutor shaft below the armature was cracked. The problem is that the magnet is pressed on the shaft and the whole shaft needs replaced. After I replaced the shaft the surging stopped. It is a costly part, $70.00 at the dealer, I found it on line for $40.00. I hope this helps.
ambainb
Apr 25, 2016 09:21 PM
