Is it my alternator or battery?
Old Oct 28, 2003 | 10:16 AM
warrior_91's Avatar
Car: 86 T/A
Transmission: 700-R4 Auto
When I was about to leave for work today, my car was dead. It would not even turn over. So I had my friend jump my car and when it was jumped, my car started up fine, but my battery wont stay charged for some reason. While im driving it, the light still flashes and makes this buzzing noise in my dash. When I go park it and let it sit for like 30 min, the battery is dead again. Is it my alternator that has gone bad or is it just my battery? Please help, I need to get this back on the road.
86 Trans Am 4bll
Old Oct 28, 2003 | 10:18 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Hmm... might be both actually. I had an alternator go bad and my battery got run all the way down several times and my battery end'd up dieing to. Call to a local autoparts store (Autozone, advanced auto) They will probably test it for free. Pretty much slap a machine on alternator output have you crank the car with the coil unpluged or pedal to the floor so it won't start. And it reads how much volts your alt is putting out. I'm sure they can test batteries too.
Old Oct 28, 2003 | 11:26 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Got to pepboys and have them test the alternator, the battery, and the starter at the same time. I say this becuase I had the same problem as you. My problem was the starter killed the battery which inturn made the alt. work to hard and by the time the alt. died, the new battery was getting ready to die again. After replacing the starter all my problems went away. At least this way your not pulling your hair trying to figure out the problem.
Hope that helps.
Old Oct 28, 2003 | 11:33 AM
Engine: 383 SBC
That makes sense too... I replaced my starter about 1 month after the alternator another month the battery died.
Old Oct 28, 2003 | 02:09 PM
iroc22's Avatar
Sounds like your Alternator isn't doing it's job anymore. Like said above, go get it bench tested.
Old Oct 28, 2003 | 05:07 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
chances are it isn't the starter unles it was the cause in the first place.
if you have a multimeter, you can put it on the battery terminals, should be above 12 volts. you can test the alternator by having the car running, unhook the battery cables, if it dies the alternator is junk. You can even hook up the multimeter to the alternator, it should be dishing out 13+ volts, make sure u give the car a good rev before u try it, sometimes if the pulley is off or the bearings in the alt don't get a good spin from the belt, it will read low.
Or if you have the time, like said take it to your local autozone/advanced. they do that for free. But if you like me, nothings around you (even a Mcdonalds, and you know theres a mc-e-d's around every corner!!!)
Old Oct 28, 2003 | 06:31 PM
Thirtybird's Avatar
Car: 91 Z28/99 WS6/02 WS6
Engine: All 350's :)
Transmission: 700R4 & 2 Tremec T56's
same thing happened to a friends sunfire about 3 weeks ago. It was simply an old/dead battery.
If the car runs fine when you get a jumpstart, the alternator is likely okay (cause it's running everything). But if you drive it around for too long with it futily trying to charge a bad battery, it will wind up working too hard and badness will ensue...
I'd have PB check the battery and the alt (just in case - since they do it for free), but I'd put a 5 spot on the cause being a bad battery :P
Old Oct 28, 2003 | 07:32 PM
RJR99SS's Avatar
just fyi, if the alternator goes; it's about an 80% chance the battery will need replacing too.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
