HeliCoil Crankshaft in 91 Camaro
Old Oct 30, 2003 | 04:17 PM
tckeeper's Avatar
The Harmonic Balancer Puller trashed the threads on my crank, in the wisdom of this site can somebody direct me to the HeliCoil Kit to repair the threads, I don't think chasing the threads will work, Helicoil looks like the last option before the machine shop.
Old Oct 30, 2003 | 05:47 PM
jamesbob02's Avatar
Car: 92 Z28
Engine: 357 TPI (L98)
I've never tried helicoiling, but I screwed up my crank threads (putting the balancer back on the wrong way) and just used a simple tap. Worked just fine.
Old Oct 30, 2003 | 07:08 PM
85TransAm406's Avatar
Car: 1985 Trans Am
did it mess up the first couple of threads, or did it trash them all?
Old Oct 30, 2003 | 07:21 PM
jamesbob02's Avatar
Car: 92 Z28
For me, it messed up a few behind the first few threads. Obviously, I was able to get the tap started so it worked fine. I don't know what it would be like if I had screwed the first threads
Old Oct 31, 2003 | 06:46 AM
ede's Avatar
ede
my guess is you never used a puller point and just screwed the puller into the crank right? second guess is all you need to do is chase the threads. to install a heli coil (7/16-24) you'd need to drill something around a 5/8 or 3/4 holt and tap it. i'd buy a tapered or starting tap and chase the threads and see what that does for you. if that works buy a installer for the dampner so you don't break something else
Old Oct 31, 2003 | 12:35 PM
jamesbob02's Avatar
Car: 92 Z28
You're absolutely right ede. I'd never done it before, but I learned my lesson. I'll always use the installer tool from here on out - SO easy!
Old Oct 31, 2003 | 06:30 PM
Vader's Avatar
Actually, the snout threads are 7/16-20. If you've buggered the threads, you can retap to 1/2-20 without even drilling. Just be very careful to pick up the lead thread and have at it.
Old Oct 31, 2003 | 08:07 PM
jamesbob02's Avatar
Car: 92 Z28
Yeah that's a brilliant idea. If you can at least get the tap started, give it a try. Definitely the simplest solution.
Old Oct 31, 2003 | 09:47 PM
Vader's Avatar
Start with a 1/2-20 plug tap, and finish with a 1/2-20 bottoming tap (if you like). It always works for me - yeah, I've learned the hard way, too.
Old Oct 31, 2003 | 09:59 PM
jamesbob02's Avatar
Car: 92 Z28
Whoa! Vader's mortal!
theurge
Aug 21, 2015 12:46 PM
LT1Formula
Aug 20, 2015 09:36 PM
383backinblack
Aug 15, 2015 06:36 PM
89mulletbird
Aug 12, 2015 07:08 PM
BBSDesigns
Aug 11, 2015 07:39 PM
