check out this lifter
Old Nov 4, 2003 | 06:27 PM
llvll4l2c91350's Avatar
is it shot?? (marks on the roller)
Old Nov 4, 2003 | 06:36 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
does the roller still turn freely?
Old Nov 4, 2003 | 06:37 PM
yes. i've checked 4 so far. this one has 2 marks, another has just 1. the other 2 have none.
Old Nov 4, 2003 | 06:39 PM
mrr23's Avatar
Engine: 360 HSR
the marks are from riding in the lifter bore. so unless it's real deep no worry. just surface scratches from what i can tell.
Old Nov 4, 2003 | 11:50 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Whether it's good or bad, don't reuse it on a new cam. It can cause premature cam lobe wear. Check the leakdown rates on it.
Old Nov 5, 2003 | 06:12 AM
ede's Avatar
ede
roller lifters can be reused with no problems, as long as they're good to start with on a new cam or old
Old Nov 5, 2003 | 01:47 PM
Tibo's Avatar
Car: 1991 Z28 Vert
You can reuse them but you could run the risk of putting grooves there that a different cam would not make their. Does that sound right? If you have the extra cash, it's best to always take the extra precaution.
Old Nov 5, 2003 | 02:22 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Don't know if you knew or not but Comp Cams and Crane, and probably most manufacturers will sell you one lifter. The cost is minimal when compared to wondering if the thing will hold up. Don't call your local speed shop. Deal with the manufacturer directly for a single replacement.
Old Nov 5, 2003 | 06:11 PM
thanks for the replies.
i just put them back in. it's just very minor scratches and i wont be using a new cam. i do plan on doing the timing set eventually, so hopefully i will have saved enough $$ by then to go all out and get new valvetrain stuff.
Old Nov 5, 2003 | 11:24 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Good luck to you. I'm going to wait till spring to do most of that stuff on my car.
db057
Apr 28, 2019 07:45 AM
64goatman
Sep 9, 2015 01:09 PM
Stryker412
Sep 7, 2015 09:11 AM
TBRays98
Sep 6, 2015 05:05 PM
z28guy134
Sep 1, 2015 11:50 PM
