When I stop at red lights...
Old Dec 15, 2000 | 05:16 PM
cobrakiller1989's Avatar
When I stop at a red light my oil pressure drops down really low. It almost goes down to the red(danger) area. I know it has plenty of oil. My questions are: Can I co something about this? And is it safe as long as it doesnt get into the red area on the gauge?
thanks in advance
Old Dec 15, 2000 | 05:20 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
well i would suggest finding out if ur gauge is right.. if you have a drop in oil pressure like that, that will eventually mean the end of ur motor, kinda sounds like ur low on oil, or the pick up is somehow fallen or moved... i guess the best bet would be to check the oil again... it doesn't hurt to double check urself...
Steve
Old Dec 15, 2000 | 06:33 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
My car does the same thing. I have changed all the oil pressure sending units. When I come to a stop light it drops also. But if I come to a hard stop my oil pressure drops to "0" and then pops back up to about 45psi's...
I wonder what the hell it could be.
wishmister@yahoo.com
1987 White IROC-Z
305 TPI LB9 273 Rear Gear
700-R4 auto tranny
97,000 miles
KYB's
Performance Resource Chip
Flowmaster Muffler
Ported/Polished Plenum by "Daniel Burk"
Holley AFPR
Throttle Body Coolant bypass
TPIS air Foil
TPIS MAT Relocation Kit
K&N's
Gutted air box
Accel 8.0 plug wires
Moroso Super Coil
Blue Streak Cap and Rotor
Boush Patinum +4's
Mobil 1 15/50 Synthetic motor oil
Mobil 1 synthetic Trans fluid.
Old Dec 15, 2000 | 06:56 PM
Blade's Avatar
Mine does the exact same thing. At first I was worried, but I Was told it could the sender. They way I see it, if the pressure wouldnt ACTUALLY drop why would the send say it does ? LOL
92 Z28 L98 350
Ported stock heads, XR270HR-10 cam, TES headers, Crane AFPR, Flowmaster catback, MSD ignition components.
Best ET 12.9@107 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Click here to see my car at Truspeed.org
Old Dec 15, 2000 | 08:26 PM
ede's Avatar
ede
first thing you need to do is put a mechanical gauge on the engine to see what the preasure really is. the factory gauge and sender aren't known for being accurate.
ICON Motorsports
1st & 3rd
Old Dec 16, 2000 | 04:22 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Oil pressure comes from bearing clearances. If your running oil that is too thin, your oil pump, while your engine is under no load, doesn't create enough pressure. Check the viscosity and the weight of your oil. After alot of wear, you have to start using heavier oil. I'm not saying start using sraight 60wt. But if your using 5w-20, try 10w-30 or what ever your climate alows.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
Old Dec 16, 2000 | 04:57 PM
I use 15/50 Mobil1....
Old Dec 16, 2000 | 05:21 PM
The engine is still brand new and I havent even started using synthetic oils yet. I am using 5w-30 right now. Do you think I should try 10w-30?
and thanks for the replies.
Old Dec 18, 2000 | 02:47 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
yes thicker = more pressure. I was running almost 50psi at idle with 10w30 and with 0w30 I have like 20psi
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 280 grind. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter
13.24@104
Old Dec 18, 2000 | 08:01 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
like the first reply said it is your oil pump pick up. try tapping the bottom of your oil pan see if you can hear some thing rattle back. other wise you may need to drop your pan. if you leave it like me (do to an upcomming eng. swap.) avoid quick stops.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
85 Jimmy
Sep 30, 2015 07:56 AM
TheExaminer
Sep 28, 2015 02:28 PM
corey8084
Sep 17, 2015 02:56 PM
MORREALE5
Sep 13, 2015 09:01 PM
