Weight?
Old Dec 17, 2000 | 01:15 PM
Casey'91Z28's Avatar
Weight?
How much does my car weigh? It is a'91 Z28 has air conditioning, no power doors or locks or seats, I removed the spare tire and jack, and I weigh about 180. I need an approxamation for my G-tech pro.
'91 Z28 305, Auto trans, K&N filters, power pulleys, ported plenum, hypertech chip, hooker cat back, kyb shocks, STB, 14.7@ 93 mph.
Old Dec 17, 2000 | 01:44 PM
327 firebird's Avatar
your cars weight should be on the sticker on the driver door. For my firebird it says 3300 pounds. The sticker includes a full tank of gas and some passengers I think 2. I was told to subtract 400 lbs from that sticker to get the empty weight. But I'm not sure. Anyone else know?
Old Dec 17, 2000 | 03:02 PM
UnderDogRS's Avatar
the weight of my camaro if i did it right is about 3700 w/ me, 1/2 tank, stero, small tool set, spare tire, ect.. how it drivers on the street. and ran a 15.6 in warm weather, about 78*. im going to pull everything this wed.
hope the get good traction and beat my 15.2.
1992 Camaro RS
Mods:
14x3 Open element w/ K&N filter, MSD 6a, MSD GM blaster Coil ,MSD 8.5 SC wires, AFPR,Fuel Pressure gauge(60Psi max), 3-Row Al rad. , 180* t-stat, Hooker 1 5/8 headers, 3" Catco cat, 3" Hooker Aero Chamber cat-back, "Ultimate TBI" mods
Best Time: 15.279@89.02MPH
Underdog Racing
Old Dec 17, 2000 | 11:45 PM
brian86Z's Avatar
my 86Z with the ac out and no power options was 3280 without me in it.
Brian
Old Dec 18, 2000 | 08:23 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
The number on the door is the weight with the max load of passengers and luggage. Probably 600-900 lbs over the true weight at least.
My 89 weighed 3180 (with 1/3 tank) with the a/c removed, fiber glass hood and all aluminum except the block.
I would say your about 3400 to 3450 with minimal gas
[This message has been edited by jcb999 (edited December 18, 2000).]
Old Dec 18, 2000 | 11:25 AM
IrocManiac's Avatar
My IROC weighs 3243 without me in it and I have about the same options as you do, however the weight jumped up about 55 lbs or so in 91. I can't remember why but I think it had something to do with the gound effects but I am not for sure I just remember reading that the empty weight of a base car was about 3310 lbs or something close to that. It was barely over 3300lbs. The cars loaded up with options weigh about 3400 to 3450. My friends 90 GTA weighs about 3500 lbs!!! but he has EVERY option.
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
"Speed kills, wanna live forever, drive a Ford."
Old Dec 18, 2000 | 07:57 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Find a government weigh station near one of your major highways and weight it. Most of the Government weigh stations where I live are not manned after a certain time at night.
And if it is manned, but no trucks waiting, just ask the attendant. Most have no problem with doing that (provided there are not any trucks waiting) and I have never been charged.
FWIW, my car weighs 3,410 lbs., no driver, minimal fuel. A full tank weighs around 100 lbs.
Old Dec 18, 2000 | 08:02 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
heh- my car's gvw is 4200 lbs or something stupidly ridiculas liek that, with a full tank my t top car wieghts in at about 3600.....power windows, a/c, no power locks, but a power drivers seat.....
steve
86 Firebird, LG4, t-tops, 2.73 open rear, SLP 3 inch cat back exhaust, catco cat.
Current Plans: 342 posi disk 10 bolt rear, coming in late december, in february or april, level 10 tranny, new convertor, june- lowering springs, possibly torq thrust II chrome wheels, and new 245 stickies up front, 255's out back, the cowl hood will be installed and painted, new cold air induction, mid summer, hoping to have enough money to scrape together a 350 hp 350... gonna keep things fairly mild.
My Webpage- Battle of the birds, My own Thirdgen Page, still under construction, http://www.geocities.com/soares711/index.htm
88 Firebird Formula- deseased 2/9/99- 305 TPI, SLP 3 inch exhaust, SLP Intake runners, SLP cam, 3.45 BW disc brake posi, WS6, NOS, and all that good stuff, 13.8 on the motor, 12.89 on NOS and slicks! Hit by what else!?!? a FORD EXPLORER!!!!!!
Old Dec 18, 2000 | 08:44 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
As a comparison, my race car when it still had the 383 in it, with me going down the track, weighed 3045. I'm not sure what the original weight was when I bought the car but it was loaded and I stripped just about everything out of it.
Going to a big block is going to add 100-200 more pounds but I might be able to shave off some more weight with some lighter parts such as a small starter and aluminum water pump. What I need now is fiberglass fenders and lexan windows.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block buildup now in progress for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Dec 18, 2000 | 10:33 PM
Stell1579's Avatar
mine fully loaded (power seat,antenna, ect..) with tire/jack/small sub box
w/o me
3680 LBS
-Stell
1988 IROC 305TPI MINT!!
Mods= Accell SuperCoil, MSD 6A, Ported Plenum, No MAF Screans , K & N, 160 Thermostat+ Temp Switch, Relocated MAT, Cold Air
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
PurelyPMD
May 5, 2016 04:57 PM
fbodyfreakls1
Oct 6, 2015 06:34 PM
Damon
Sep 26, 2015 04:29 PM
HikoriYami
Sep 21, 2015 07:11 PM
