pre-85 engines
Old Nov 10, 2003 | 10:43 PM
SchwarzCamaroRS's Avatar
pre-85 engines
I was planning on swapping a pre 85-350 into my 91 camaro cuz they are a LOT cheaper than the ones i have found. Where could I get an intake for one of those? or, can I put heads from after 85 on it?
Old Nov 10, 2003 | 10:53 PM
pauldaniel26's Avatar
Car: 1986 IROC-Z28
Engine: 355 in the works...
Any heads will bolt to it. It's essentially the same block but w/ a 2 pc. rear main seal and does not have the provisions for a roller cam.
Old Nov 10, 2003 | 11:25 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
could use heads made after 86, or you could simply modify your intake to bolt up to the pre 86 heads, all the ports line up you just need to re angle the holes for the center 2 bolts on each side of the intake to make it fit, pretty simple to do really.
Old Nov 11, 2003 | 02:42 AM
nice, i was planning on putting some vortec heads on it eventually.. now I know its possible tho.. sweet a$$ thx
Old Nov 11, 2003 | 10:06 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Yeah it will work. The main difference is just the intakes. The middle bolts will be angled different. Thats the only thing thats different really. If you get a head like the vortecs youll need a new intake anyways.
Old Nov 11, 2003 | 01:49 PM
awesome. Now i can have new and old parts on it me = really happy ;-)
Old Nov 12, 2003 | 04:29 PM
umm... will i be able to put a Tremec T-56 on this setup? cuz thats the trans I want... and i will cry if its not possible
Old Nov 12, 2003 | 04:41 PM
Momar's Avatar
Chevy has used the same bellhousing bolt pattern for the 4.3 V6, small blocks, and big blocks from the early blocks clear up through the LT1. You will however have to have a flywheel for an older block. I have a normal t56 on my 78 block, but I have an aftermarket t56 flywheel for it where as you would need an early t5 flywheel I believe.
Ben
Old Nov 12, 2003 | 04:44 PM
i knew that i had to replace my flywheel just cuz of the seals, but is there a specific flywheel i have to buy to fit the t-56?
Old Nov 12, 2003 | 04:49 PM
Momar's Avatar
you said tremmec. I assumed that you were planning on using the aftermarket t56 which uses the stock t5 bellhousing, clutch, and flywheel. If you do that you just use the stuff that is made for a early t5. If you get one out of a fourtghen, it has to be 93-97 which were made by borg warner, you have to get an aftermarket flywheel which will run you about 350 by its self. If you dont know tremmec bought the t56 from borg warner and they made it durning the time of the LS1. Those transmissions will NOT fit on our motors at all.
Ben
Old Nov 13, 2003 | 01:31 AM
hmmm... so what exactly do I need to buy, in regards to flywheel, trans year and all that
Old Nov 13, 2003 | 01:32 AM
Momar's Avatar
Which type of trans were you planing on going with?
Ben
Old Nov 13, 2003 | 01:34 AM
any 6 speed trans really, i really like the t-56, and its the only one ive seen swapped into a 3rd gen... i saw these online http://www.standardtransmission.com/BW_T-56.html
and thought they might work, but i dunno...
Old Nov 13, 2003 | 01:37 AM
Momar's Avatar
Well, I figured you meant t56. Were you planning on a stock one out of a fourthgen or an aftermarket one. If you dont have a t5 now I would definately go w/ the fourthgen tranny. If you have a t5, it depends on how much it is worth to you that it is brand new.
Ben
Old Nov 13, 2003 | 01:38 AM
i was guna get the aftermarket one from that site, w/ the shifter modded to be located where the one from the 700R4 shifter is now... but whatever is easier is what i will do
Old Nov 15, 2003 | 05:31 AM
Im a bit confused on what flywheel to get... Ive read that the pre-86 engines have 3.58" crank bolt patterns, while my car, a 1991 model, accepts the 3.00" bolt pattern on the crank. But i still do need the 2-pice seal for adding the pre-86 engine... does anyone know where to get a flywheel with 3.00" crank patterns and a two piece seal configuration? or is that even what I need?
Old Nov 15, 2003 | 02:02 PM
Momar's Avatar
If you change to a 2 piece rear main seal block, you have to change to the other style flywheel bolt pattern. This means that if you go with an older block you have to get a different flywheel. You could get one for a t5 in an f body from a couple years earlier w/ the 2 piece style flywheel.
Ben
Old Nov 15, 2003 | 03:06 PM
i fould a pre-86 flywheel, but it has the older bolt pattern, how am i supposed to bolt it to my crank if it has a different bolt pattern?
Old Nov 15, 2003 | 04:54 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Get a 85-back 153 tooth (12-3/4" dia) flex plate.
Old Nov 15, 2003 | 05:49 PM
Momar's Avatar
It wont bolt to the crank you have now. It will bolt to the 85 and earlier block you were asking about.
Ben
Old Nov 16, 2003 | 06:02 AM
oh makes sense... well, i feel a bit off... haha... anyways, thx guys, hopefully by next week ill have the beast back running again!!
Old Nov 18, 2003 | 01:45 AM
I just contaced the ppl i was gunna hve do it and they said now way in hell this setup would pass california smog... is there really any crate engine out there that will???
Old Nov 18, 2003 | 07:33 AM
Momar's Avatar
Well, visually, any small block will look the same so it would be hard for them to catch you on a visual unless they took numbers off of the block. I dont know as far as actually passing the sniffer. I do know that they are pretty strict out there. I dont know if there are any crate engines that are approved or not though. If there are you will definately need to keep all of your origional emissions equiptment. Maybe someone with more experience w/ cali emissions could help you more.
Ben
Old Nov 18, 2003 | 01:20 PM
yeah, I have all my stock emissions stuff still in tact, my car is 100% stock except for the catback exhaust and the ecm chip. I have someone who could pass a small smog failure, but if it is too much, he wont do it
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
