Setting the Valves...have an issue
Old Dec 3, 2003 | 11:05 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
Today i "tired" to lash my valves and ran into some problems...i know the prcedure and i beleive i executed it correctly..
while the engine running loosen the adjusting nut (in my case an ARP poly lock) untill it taps then tighten till it stops then go another 1/4 turn..i did this to the entire driver side and then turned the motor off...i tired to move the rockers and sure as **** they were loose...i went and did the other side and wehn i was done they werent as bad.. WTF is going on...
BTW...Stock LT1 cam..LT4 heads have .525 max lift springs installed
Old Dec 4, 2003 | 12:57 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Sounds like you did it right. I'd went an additional 5/8 of a turn instead of 1/4 turn.
Some of the rockers will be loose after eng is shut off since the hyd lifters bleed down.
Some of the rockers will stay tight if their respective valve is open.
That's normal.
Old Dec 4, 2003 | 04:56 AM
ede's Avatar
ede
lifters bleed down and makes rockers loose, nothing to worry about
Old Dec 4, 2003 | 11:32 AM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
That's normal.
DOUBLE ..youd think id remember that
heres anotehr one for you 2...whats the advantages/disadvantages to preloading the lifters 1/2 turn to a 1/4 turn?
Old Dec 5, 2003 | 11:54 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
i read that some guys use a full turn after lash...
right now my valves are set to a /4 turn but there still makin some noise not really a clap more lile a little tickx16
Old Dec 6, 2003 | 12:07 AM
demonchild's Avatar
im not sure about the roller blocks, but my 85 lg4 liked 1/2 turn after no noise.
Old Dec 6, 2003 | 12:27 AM
nosfed454's Avatar
Car: z 28
Engine: 454
on hyd lifters on my car i set them with the motor off.
it works good for me coz the high pressure oil pump gets oil all over.
but i also set them running some times.
Old Dec 6, 2003 | 07:15 AM
ede's Avatar
ede
i use "more than 1/2 turn" after zero lash. never had any problems and i'm not all that precise with how far past 1/2 turn i go, but never exceed 3/4 turn.
Old Dec 6, 2003 | 11:08 AM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
thanks guys..ill set them another 1/4 turn today and see how much that helps..
Rob
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
Street Lethal
Apr 30, 2019 12:14 PM
evilstuie
Feb 28, 2016 03:33 PM
bamaboy0323
Sep 3, 2015 06:07 AM
