305 block + 350 heads will it work
Old Dec 31, 2000 | 10:23 AM
cougar20th's Avatar
Car: Black 88 Iroc Convertable
i have a 305 shortblock thats bored .030 over(so im told by the guy i got it from for free) and i have a tpi 350 out of a 89 formula will the block and heads work together?. i plan on putting it together for a project i have and then putting the tpi on it.
Keith
85 Berlinetta WS-6
87 Cougar 20th Anniversary
Old Dec 31, 2000 | 12:06 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
I think the intake valve comes very close to the cylinder wall on any cam that has more than about .45 lift.
Old Dec 31, 2000 | 12:21 PM
ede's Avatar
ede
a lot of 305 heads have smaller chambers than 350 heads. so the compression would be higher, but 305 heads don't flow very well. there is also the problem of the valve hitting the deck surface with very much cam lift.
ICON Motorsports
1st & 3rd
Old Dec 31, 2000 | 04:35 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Hey ede, I think you didn't read the post too well. With the 350 heads, (76ccs) the compression ratio would be too low. The 305 heads, (58cc) would be what you need. You wont get enough power, and produce too much emisions, if you have testing.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
Old Dec 31, 2000 | 07:03 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Compression will probably be about 7.x:1 because of the large combustion chambers. It would be good if you had a blower on the engine with lots of boost.
Depending on cam lift, the valves may hit the block. 2.02/1.6 valves will definately not work with the 305's small bore and the stock 1.95/1.5's are close.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block buildup now in progress for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Jan 1, 2001 | 04:11 PM
cougar20th's Avatar
im planning on building the motor stock nothing fancy. from the sound of it i should just get a 350 shortblock to work with. im trying to rebuild the 64 f100 im going to put it in for as little $ as i can so a blower is totaly out of the question. thanks for the help
Keith
85 Berlinetta WS-6
Old Jan 1, 2001 | 04:17 PM
snakeskinner's Avatar
I believe the heads you have will work on the 305 no problem. you cannot run a 2.02 head on a 350 because the valves will not clear the cylinder walls but I believe the L98 heads have a 1.88 intake and will clear. I also believe those heads have a 58cc chamber, not 72cc but verify my information before you do anything. mic your cylinders and you can find out if they are bored or not. If it has pistons in it, they should be stamped .030 somewhere on the face.
Kyle Osterholt
Okarche, Oklahoma
ASE Master Certified
86 T/A 383 TPI
89 TTA #1002 T-top/Leather
89 TTA #1358 Hardtop/Leather
80 T/A Pace Car
73 Opel GT
Old Jan 1, 2001 | 04:44 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
the iron L98 heads have 64 cc combustion chambers
Kyle is thinking of the aluminum L98 heads with 58 cc combustion chambers
most 305 heads are between 55 and 58 ccs
if you bolted on l98 iron heads to a 305 it would be a dog
Old Jan 2, 2001 | 04:50 PM
GeneralHazzard's Avatar
no offense, but 2.20 valves WILL clear on a 350. what do you think those camel hump heads came on? 350's and 327's both same bore. on a 305 i dont know.
theshackle
Mar 5, 2017 06:37 PM
Reborn756
Sep 4, 2015 03:42 AM
camaro71633
Sep 1, 2015 10:24 AM
st.evel07
Aug 13, 2015 06:15 PM
BBSDesigns
Aug 11, 2015 07:39 PM
