blowing oil out the dipstick???
Old Dec 7, 2003 | 02:57 PM
jmon92conv's Avatar
under hard driving (any other) my Z will blow oil out the dipstick Any ideas? THe stick clips in, and really doesn't get loose, the oil just seems like it blows around the rim.
Jeremy
Old Dec 7, 2003 | 03:01 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Is that what the kids call it these days?
Seriously...
Check the PCV. The only reason the dipstick will blow out is from crankcase pressure.
If it's not the PCV, you could have major blow-by from worn rings.
Old Dec 7, 2003 | 03:19 PM
jmon92conv's Avatar
I don't think it is rings. No smoke in exhaust. PCV rattles when shaken. I will replace anyway (cheap). This just started all the sudden, I keep very good care of my car and would pick up on earlier indications of rings.
Jeremy
Old Dec 7, 2003 | 10:20 PM
jamesbob02's Avatar
Car: 92 Z28
Engine: 357 TPI (L98)
AJ's right. This happened to me when I first got my Z, and it was the PCV system. Your PCV valve may be fine, but what I didn't realize about mine for too long, was that somebody had put TWO PCV's in it, the other one in place of the 90 degree fitting on the passenger side valve cover. The two worked against each other and screwed up my oil pressure, and I had a mysterious oil leak that would burn on the headers and choke the engine, throwing all sorts of codes that went nowhere.
Definitely check ALL parts of the PCV system.
Old Dec 7, 2003 | 10:21 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
clogged PCV hose
Old Dec 7, 2003 | 10:22 PM
jamesbob02's Avatar
Car: 92 Z28
Good point, as well. Could be a clogged PCV port in the intake manifold as well, or on the TB, although those are small chances.
Old Dec 7, 2003 | 11:59 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Time for a better breather on the opposite side valve cover.
Old Dec 8, 2003 | 08:18 AM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
take the pcv valve out of its hole and put your finger on the end, there should be a lot of vaccuum there at idle and the engine rpm should change when you do it. if its not the vac hose to the pcv valve may have a leak. also make sure the breather is connected to the intake on the other side of the engine.
Old Dec 8, 2003 | 02:15 PM
Fairly Strange's Avatar
Car: '89 Formula
Engine: 305 TBI
Do the pcv and breather routine....good thing to check before more invasive surgery.
If that don't cure it, rings are gone......no, you won't necessarily see smoke out the back with bad rings.
That all depends on which ring/rings on which cylindar/cylindars "went south"!
As an example, I have an '83 Cierra in the back drive that blows oil out of every oriface it has....except the tailpipe. I didn't mind that so much until the rod started knocking!
Old Dec 8, 2003 | 06:56 PM
jmon92conv's Avatar
bought a new pcv valve today, the old one was much heavier and rattled just a little bit. It was pulling vacuum but I will inspect the rest of the system when I am home during daylight. ( I only drive the car app 100 miles a month no time ) I really dont think it is the rings. Also, it seems I remember something on the other side of the engine It has been a few years since I did the plenum porting I cant remember exactly.
Jeremy
Old Dec 8, 2003 | 07:40 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's combustion getting into the crankcase, one way or another.
Exhaust valve guides (possible)
Rings (probably not)
Intake gasket leak, at the center, around what people call the "EGR passages" (highly likely)
Cracked head (highly unlikely)
Broken piston (possible if the engine has been severely overheated or subjected to nitrous)
Old Dec 11, 2003 | 01:59 PM
jmon92conv's Avatar
just an update, new pcv valve seems to be working. Only put about 20 miles on it, but that was more than was needed before.
Jeremy
Old Dec 12, 2003 | 10:37 PM
stevedave454's Avatar
Car: 91 S10
i had an 84 4 cyl fiero that would blow oil/steam out of the oil filler cap like a fountain because of its MASSIVE blowby, but NO smoke out of the tail pipe, and passed emissions with flying colors, so dont rule that out.. i dont ean to scare you or anything, sounds like it might have been the pvc, but dont rule out the rings
tyeo098
Nov 30, 2015 06:27 PM
codeysabatini
Nov 10, 2015 04:07 PM
BDR
Nov 7, 2015 03:05 PM
Stryker412
Sep 20, 2015 06:59 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
