what do u think of this combo?
Old Dec 7, 2003 | 06:47 PM
emtcee's Avatar
Car: 67 camaro
Engine: 383 accel dfi
Transmission: t56
tell me waht u guys think of this combo for my 67.its going to be a 383 stroker motor.eagle cast stroker kit with -5cc flat tops.heads are going to be afr 190's(not sure if i should go with 74 cc or 64 cc chambers let me know on that one)i have a few cams that i am looking at one is the lunati hr11 specs are @.050" dur intake:226 exh.234 lift @valve is intake.530 exh. .530 lobe sep 112deg. dd200 says 506ftlb@3500 rpm and 429hp@5000 rpm.now the other 2 cams are also lunati specs are pretty close to this one.this is going to be a tpi motor(ported out)and a t56 trans.this car will never see track time so i probably won't rev it past 5000rpm anyway.i know dd2000 is optimistic but what should i expect out of this combo in real life at the wheels?also looking to get about 10:1 compression.this is a HYDRAULIC roller cam by the way.let me know all of your opinions good and bad. i really want a killer street motor.also i have an accell dfi i am going to use on this. also large tube headers with flowmasters.
Old Dec 7, 2003 | 08:12 PM
Insomniac92z28's Avatar
Car: 92Z28
Transmission: A4
300-320rwhp with the TPI. Gobs of torque though, from what I've read the TPI is maxxed out at around 320rwhp (ported too the max). I think you would benefit greatly from a superram intake. I just can't see building a monster motor and feeding it through a straw. Let that beast breath and spin some RPM and it will be a mean machine. The cam looks pretty good. I really don't think the AFRs need the split to the exhaust though.
Good luck,
Charlie
Old Dec 7, 2003 | 08:29 PM
emtcee's Avatar
Car: 67 camaro
Transmission: t56
thanks for the relpys guys.any more opions would be great.
Old Dec 7, 2003 | 09:19 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Re: what do u think of this combo?
AHHH...need paragraphs, lol
With DD2000 the best way I found to make them compare with real dyno numbers is to put in the actual flow of your heads, then change from "small tube headers" to "HP manifolds" and to always tell it its a hydraulic cam.
Sounds like it'll be a nice running motor, I heard AFR dropped the 190s because of their 180s. So now its 180,195,210...
Old Dec 8, 2003 | 07:38 PM
emtcee's Avatar
Car: 67 camaro
Transmission: t56
money is definatly a concern that is why i want to go with a stock ported tpi set up plus ialredy have it sitting in my shed.i do have slp runners for it and plan on buying a 58mm throttl body.do u think that these upgrades will help at all?maybe down the road i can save some money to get the accell unit, but for now i was hoping i could get some good numbers with the stock unit.let me know whay u guys think.....:hail:
Old Dec 8, 2003 | 07:43 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No.
TPI's main restriction is the lower intake. All else is merely nibbling around the edges as long as that's there.
With a non-restrictive intake tract, you trade off the "tuned" effect which produces the torque peak at 3600 RPM and the anti-tuning above 4500, in exchange for some flow.
Old Dec 8, 2003 | 07:47 PM
emtcee's Avatar
Car: 67 camaro
Transmission: t56
so if i bite the bullit and buy an after market lower intake and use the stock upper it will help out a lot?along with the other thing i metioned? :hail:
Old Dec 8, 2003 | 08:32 PM
Momar's Avatar
No. I dont really believe that the lower intake is problem, but the long tube runner design over all. The long runner design is tuned to give torque but gives up high end. If you are willing to consider buying a lower intake, I have one question. Emissions? Where do you live, and what kind of emissions checks do you have? I would suggest that if you do not have emissions that you consider the converted LT1 intake. It flows much better and can be picked up pretty cheap. My friend has bought a couple from the classifieds for three hundred and some dollars each. One of them came w/ the fuel lines and remote thermostat housing. This converion can be done for about the price of a lower intake if you watch for a deal. Then if you sell your runners you will get some of that back. I just think you will be loosing out on a large amount of power by sticking w/ the long tube runner design.
Ben
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
roysatikas
Sep 22, 2015 08:15 PM
z28guy134
Sep 1, 2015 11:50 PM
