Static Electricity
Old Jan 6, 2001 | 08:22 PM
clewis's Avatar
Car: 1985 IROC-Z
Engine: 305 Tuned Port Injection
Static Electricity
Don't know if this is the right message board for this post, but here goes. I have an 85 IROC, no power anything. I do however, have an UNGO Box TL 4000 alarm installed under the drivers seat and an alpine amplifier under the passenger seat. Lately, when I get out of my car and shut the door I get a shock. I really don't know where to start as far as looking for a problem. Or is there a problem? I would appreciate any suggestions.
Thanks,
Clewis
Old Jan 6, 2001 | 08:56 PM
GearHead1973's Avatar
Since this started happining have you maybe got new clothing. Like a coat that builds up static electricity. Just a thought.
Old Jan 6, 2001 | 09:29 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
Dry winter weather is the culprit. I could explain the hole static electricity thing but I do have the time to type and you do have the time to read it. In laymens terms dry air= more static, humid air = less.
87 Z28 305 TPI, Auto, 2.73, Gutted air boxes, K & N fillters, SLP Airfoil, Dyno Max 3" cat back, Accel 8.8 mm spirals, Accel cap and rotor, Accel coil, rapid fires, and 160 Stat.
Best 15.414 @ 87.47.
Old Jan 6, 2001 | 11:01 PM
Vader's Avatar
Clewis,
That's relatively normal. My wife's new Astro zaps her every time she gets out of it. I think the tire rubber compound is softer and more prone to static generation. The old one never did that.
I think its pretty funny, myself. I tell her that since she can't give me static when I'm not around her van is returning the favor in my place.
Later,
Vader
"I cannot take this any more... Saying everything that I've said before..."
Adobe Acrobat Reader 4.0
Old Jan 7, 2001 | 01:26 AM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Good explanation Vader! That was pretty funny!
I sometimes get a shock when wearing different shoes!
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
Awaiting results from all 8 ASE tests.
Starting to look like the Kicker poster child!
Old Jan 7, 2001 | 01:37 AM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
Rubber is an insulator, static is just looking for ground. Different rubber, different resistance. The rubber on the bottom of your shoes.
Old Jan 7, 2001 | 11:26 AM
clewis's Avatar
Car: 1985 IROC-Z
Thanks to everyone who responded. I had a feeling that it had something to do with our winter weather. However, since I've also had a problem with fuses blowing whenever I use my cigarette lighter port to play my portable CD player, I thought that I might have a short somewhere.
Old Jan 7, 2001 | 05:04 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
The cigarette lighters go bad all the time. I had to take mine all the way out to make it staop blowing fuses.
[This message has been edited by new87 (edited January 07, 2001).]
db057
Jan 10, 2020 08:55 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
lanceflame44
Sep 25, 2015 12:28 PM
