question about changing thermastat
Old Dec 17, 2003 | 11:00 AM
nj88's Avatar
Car: 1988 formula 350
Transmission: auto
hi im new to the boards, i just bought another formula,,ok my question is this im changing out the thermastat. but i cant get to the bolt my the manifold. i took all the proper hoses off to get to the bolt but i still cant its a tight fit can someone please help with this problem. the sockets i have cant get to the bolt even with an elbow socket.
its a 1988 formula 350
Old Dec 17, 2003 | 11:26 AM
ede's Avatar
ede
what induction system? if it's tpi it's lot easier to remove the TB first
Old Dec 17, 2003 | 11:32 AM
nj88's Avatar
Transmission: auto
my bad it is a t.p.i, tb all that for a therm my 89 tpi formula 305 was alot easier. thnx dude
Old Dec 17, 2003 | 02:00 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
its mo dude, mo
Old Dec 17, 2003 | 02:53 PM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
There's no need to take anything of, to replace the thermostat on a TPI car.
Just use the right tools, and prepare to work in a narrow space!
Old Dec 17, 2003 | 04:20 PM
Dubbs2u's Avatar
Car: 88 formula
Engine: tick tick tick
Transmission: slipping one
When we replaced the therm. on my 88 formula... we only had to take off the intake tube going to the TB... everything else was just tight... just go to an auto parts store and find a socket that you can fit in there...
Wendell
Old Dec 17, 2003 | 05:07 PM
Thirtybird's Avatar
Car: 91 Z28/99 WS6/02 WS6
Engine: All 350's :)
Transmission: 700R4 & 2 Tremec T56's
open ended wrench on the front one (between the fuel lines - be careful!) - distributor wrench (of all things) on the rear ... was the easiest way to do it without removing anything but the induction and upper rad hose...
Old Dec 18, 2003 | 03:57 PM
Jesus's F-Bird's Avatar
Car: 83 Pontiac Firebird S/E
Transmission: Borg Warner T5
Try using a wrench instead of a socket, and if you have 3 dollars to waste, and you REALLY need to get to the thermostat, you can bench the wrench at just the right angle (use the open end) and it makes it real easy, wrenches fit into places were socets do not
Old Dec 18, 2003 | 06:37 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
man i'm so happy with my carb =]
changing the therm is a one minute job, i feel for you guys.
Old Dec 18, 2003 | 08:34 PM
MikeS's Avatar
Try a 6" wobble extension. You can put the socket on the bolt, the extension in the ratchet, and halfway put the extension into the socket...
Frozer!!!
Jan 19, 2024 04:55 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
