is this a fuel pump problem?
Old Dec 23, 2003 | 01:48 PM
FBird84's Avatar
The car shut off on me and it won't start the motor turns but it won't start.
I sprayed some carb cleaner spray on it and it starts right up but it soon dies. The guy that push me home said it might be a dead fuel pump or maybe a line problem.
Where is the fuel pump on these cars and how hard are they to change?? do i need some special tools or anything? I'm gonna put a few dollars worth the gas in it to make sure i didn't just run out of gas or anything. Could there be any other problem?
Old Dec 23, 2003 | 02:27 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What year and engine?
Old Dec 23, 2003 | 04:03 PM
FBird84's Avatar
1984 Firebird 305 LG4
Old Dec 23, 2003 | 06:17 PM
FBird84's Avatar
can anyone help? when i turned the key i can hear a clicking noise this is the fuel pump right?? The engine turns but doesn't start. I've been having a problem with the carb idling to high could this have damage the pump?? Is the pump in the tank? How hard is it to change?
any help is appreciated
Old Dec 23, 2003 | 06:21 PM
BadBlue91RS's Avatar
Car: 1991 Camaro RS
Engine: Briggs & Straton
Transmission: Centrifical Clutch
That clicking in the A/F solonoid on the carb....other than that, I have no clue man...sorry.
Old Dec 23, 2003 | 06:40 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There should be a pump on the side of the block, down low, on the pass side, right at the front. AFAIK there isn't one in the tank, but some of these cars got both the block-mounted pump and the in-tank one; so there might be one of each.
It could just be your fuel filter is clogged.
You can tell right away if it's the pump. Disconnect the fuel line from the carb, which requires a 5/8" tubing wrench to turn the flare nut, and a 1" wrench to hold the other big nut still that the line goes into. Take the line loose and put something like a coffee can under it, and crank the engine over, and see if anything comes out as you crank. If it doesn't, you probably need a pump. If gas comes out, the fuel filter is probably clogged. It lives inside the big 1" nut you had to hold still. Take that nut out, and it will be obvious what you need to do.
It's about $15 or less, and pretty easy to change from below.
Old Dec 23, 2003 | 06:51 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
and if it needs a pump, see if your oil smells like gas, if yes, change it before starting
Old Dec 23, 2003 | 08:23 PM
FBird84's Avatar
thankx guys i'll check it out 2morrow and let you know what i find.
Old Dec 24, 2003 | 12:01 AM
FrozenFirebird's Avatar
Should also be able to open the choke plate, and with a flash light look down the barrels and pump the throtle a couple times and look for fuel squirting into the carb.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
