Anyone done a 434?
Old Dec 30, 2003 | 04:52 PM
zerotosixtyV8's Avatar
Car: Camaro
Anyone done a 434?
Just curious to see what parts you used and how it performed? I'd like to do a 434 but I've heard that you can't do it with a stock block because of the crankshaft clearance in regard to the cam. is this true?
Old Dec 30, 2003 | 05:33 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes.
Eagle crank and ESP rods. I don't recall for certain, but it seems we used an off-the-shelf Comp XR282HR cam.
We put teh Accel Pro Ram on it, with a Haltech.
It ran pretty hard. It was in a 4WD Blazer; last I knew it, the owner didn't have it all the way dialed in, but it was getting close. Then he tore up the trans (700R4). Oh well.
It was a stock block (509).
Don't believe anything you hear from people who haven't done it. Seems like everbody that's never done it will tell you all about it, and they're usually all wrong.
Old Dec 30, 2003 | 05:52 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
RB, is the extra cubes worth the cost over say a... 406?
Old Dec 30, 2003 | 05:56 PM
Car: Camaro
sweet RB, I know ebay links aren't allowed for some reason, but would this be the eagle kit you used by any chance? http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting it's a 6" ESP rod, 4340 eagle ESP crank and forged Ross pistons in the kit. the 11.8:1 compression is what I'd have with my heads, but I could get a thicker head gasket and try to bump compression down to 11.5:1 and try to run it on 95 octane.
is the pro ram the EFI carbureted style intake? I was thinking a stealth ram on this motor, with a wild cam (260-270 duration) and .600" lift to match my cylinder heads flow (approx 270 cfm at .600" lift) as close as I can to the HSRs flow with a 58mm TB (approx 275). ported plenum of course. I've got a 700r4 pro built that is supposed to handle a BBC torque and 700 HP but we'll see how well it holds up behind a 434. a 2800-6800 rpm powerband would be great, with an ability to spin it out to 7000 rpm if necessary. I've already got 3000 stall and 3.27s, I don't think it'd be too soft on launching with that kind of motor but I'll see when I do it. tell me what you think?
Old Dec 30, 2003 | 05:57 PM
Car: Camaro
for near 650 HP all motor I'd say $500-$600 more for a rotating assembly would be worth it!
Old Dec 30, 2003 | 06:37 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
A 434 is usually had by using 4.1550" bore and 4.000" stroke. To the best of my knowledge this is only accomplished by using an aftermarket block, such as, World or Dart. A fully machined ready to biuld World or Dart block is about $2,000. I'm not sure but maybe GM performance blocks might be able to be bored to 4.1550".
For a 434, I think something special has to be done with the cam,, either small base circle or relocating the cam position higher in the block.
BTW: I am doing a 395cu in. stroker motor using a stock 4 bolt GM L98 block.
Old Dec 30, 2003 | 06:50 PM
Car: Camaro
a 406 has a 4.155" bore. RB said that he used an off the shelf cam. I've heard that a small base is needed or a shaved counterweight crank.
Old Dec 31, 2003 | 12:38 PM
Car: Camaro
would a 511 block work for this as well?
Old Dec 31, 2003 | 02:55 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
I believe the Dart and World blocks are special castings, too, with raised deck heights.
TRANSAMCRAZY
Apr 30, 2010 05:34 PM
dhirocz
May 15, 2007 11:39 AM
86irocznj
Jan 2, 2005 05:53 PM
89TA383M5
May 6, 2004 01:05 AM
ZOnFire
Feb 10, 2004 11:43 AM
