Wrist pins slide out? Is that right?
Old Jan 11, 2004 | 08:35 PM
johnybravo129's Avatar
Car: 1985 Camaro
Engine: 350 ci 4 bolt main .30 over forged fed mogul pistons
I'm a newb to engine building, and I just got this 4 bolt main with brand new federal mogul forged pistons. There are write pins installed in the pistons but u can slide them from side to side... I thought there were supposed to stay put?? I know this is prolly a retarded question, but I"m just concerned... Like 7 of the 8 pistons' wrist pins can slide, one cant... I mean, their brand new, literally in the box... So nothing can be wrong with them... I dunno, lemme know! Thanks!
Old Jan 11, 2004 | 08:52 PM
Brett H. - 89GTA's Avatar
Car: 1989 GTA
Engine: 5.7L
Axle/Gears: 3.27 BW 9-bolt
Are they set up for a floating pin? If so then they use retainers to keep the pin in place.
Old Jan 11, 2004 | 09:09 PM
Car: 1985 Camaro
I don't have any clue... Where would these retainer pins go and how much do they cost? Someone's helping me with the build and I just haven't asked him yet.. If u gimme a minute I can prolly post a picture of the piston.
Old Jan 11, 2004 | 09:13 PM
Car: 1985 Camaro
here
Old Jan 11, 2004 | 09:20 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
they are supposed to slide. When you press the rod onto the pin, the rod holds the pin inside the piston.
Eric
Old Jan 12, 2004 | 12:57 AM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
If you have floating pin pistons, there will be a bronze bushing in the pin bore on the top end of the rod. If there is, then the pins should be held in place by clips that fit into the tiny grooves in the piston on either side of the pin.
If you don't see any bushings in the rods and the pins slide, something's defective.
The clips are supposed to come with the pistons, but if they're used pistons then they should get new clips anyhow.
Old Jan 12, 2004 | 04:33 AM
ede's Avatar
ede
the pin is pressed on the rod and floats on the piston or the small end of the rod is bushed and the pin floats on the rod and snap rings or spire locks keep it in place on the piston.
wigmobile
Feb 26, 2025 02:56 PM
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
gta892000
Sep 16, 2015 12:37 AM
