new engine won't start
Old Jan 31, 2004 | 05:02 PM
stupidrocs's Avatar
We built a new 350 for my buddy's 86 iroc it is a tpi set up with vortec heads. It is timed right, we have spark and fuel, but no start. I checked it with a scanner, it has no codes, but also the TPS shows no voltage, also the O2 shows no volts. I have checked ground straps, changed chips, and different things. What am I missing? It turns over and if I move the dist. it will spit back but no start. Any suggestions?
Old Jan 31, 2004 | 09:54 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Sounds like timing.
How did you time it?
Check the TPS with a voltmeter. I've seen scanning s/w that won't read right for one sensor, but eng runs fine.
Old Feb 1, 2004 | 12:11 AM
BadBlue91RS's Avatar
Car: 1991 Camaro RS
Engine: Briggs & Straton
Transmission: Centrifical Clutch
With KOEO (key on engine off) there should be voltage at the TPS...a 5 volt refference that will suply power to the sennsor. The refference signal for that and other sensors comes from the computer. You must check at the sensor itself to see if the refference is there.
Old Feb 1, 2004 | 08:53 AM
stupidrocs's Avatar
I degreed the cam when I installed it, then put the mark on the balancer on 0 and the dist. lined with #1, and turned randomly while tring to start.
Old Feb 1, 2004 | 10:40 AM
mikesz1984's Avatar
Car: 1984 z28
i am not sure that you can with chevy, but with some other brands it is possible to have the distributor out 180 degrees, i have seen it on a dodge before and it acted very much like you discribed
Old Feb 1, 2004 | 09:40 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
If you put the rotor facing #1 with the balancer at "0"; you have a 50/50 chance it's in right.
If you put the rotor facing #1 with the dots on the crank/cam gears close to each other, it's definately 180 degs out.
Turn the dist 180 degs and try again.
Old Feb 2, 2004 | 06:10 AM
ede's Avatar
ede
if you installed the crank and cam gears dot to dot and lined the rotor up on #1 you have it 180 out.
Old Feb 2, 2004 | 10:48 AM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
exactly, find TDC of the compression stroke for the #1 piston, then install your distributer with the rotor facing the #1 cylinder.
thats should get your timing close enough to get the engine fired up.
its really easy to stab the distributer 180 out, i've done it before.
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
