What Cam?
Old Feb 12, 2004 | 01:29 AM
Duke901's Avatar
Car: 89 Formula
What Cam?
What cam do you think would be better for this motor? 85 tpi 305 9.5 compression that has been changed to a edelbrock rpm intake and a holley 650 carb, 700r4 and a 3:42 gear. I would like to get a summit cam sense they are cheaper. Thank you
SUM-K1103 214/224 442/465 with a 112 lobe
SUM-K1105 224/234 465/488 with a 114 lobe
Old Feb 12, 2004 | 06:21 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Neither of those cams is worth the price. I would not use either one even if they were free.
You're talking a difference of practically pennies between those old crappy generic cams (especially the second one.... ugh) and a good, modern, appropriate cam. The first one isn't as bad, but you can still do a whole lot better.You're going to go through all sorts of labor, you'll spend a whole bunch of other money on gaskets, hoses, fluids, and so on. Why shoot yourself in the foot that bad over that little money?
For $18 more you can get a Comp XE cam. $18 .... The similar Crane products are about the same price. Your car will run so much better with one of those cams compared to those lazy ancient grinds, it isn't funny. Don't do that to yourself.
I'd go with the Comp XE262 for that combo.
Old Feb 12, 2004 | 10:57 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
IIRC, Crane is giving free lifters when you buy an Energizer cam. $99.95 at www.Summitracing.com
$20 more including lifters.
Old Feb 12, 2004 | 12:28 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That's the same price as the Comp ones (the K-kit); probably Lunati and the other top-line type ones too. Pretty standard pricing.
Old Feb 12, 2004 | 12:56 PM
Duke901's Avatar
Car: 89 Formula
Ok thank you, also i plan on porting the heads. Could i go any bigger then the ex262? Like the ex268 or the ex274 if a get a 2200 stall.
Old Feb 12, 2004 | 01:04 PM
AJ_92RS's Avatar
What have you been smoking?
An XE cam for $100 does not include lifters. The kit for the lifters is $170.
The K-kit is EVERYTHING - camshaft, lifters, valve springs, retainers, locks, valve seals, timing set, assembly lube, instructions, and decals (gotta have those stickers ) for $310
Who's money is this? Yours or his?
Old Feb 12, 2004 | 04:28 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Old Feb 12, 2004 | 07:41 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
The Summit/Generic cams are not near as lazy as RB would have you believe. but....
With only a 2200stall converter on a 305 you don't want to get too carried away with the cam though.
The summit K1103 would be the largest you'd want.
214-224-.442-.465-112
The summit K1102 would be the one for a stock converter.
If you want to use a larger cam (224+@.050") wether Summit brand, Comp XE series or whatever, you would want a 3000+stall converter for a 305 as the low end torque would be less than stock.
We're talking about a 9.5" high stall for a 700r4.
Choose something in the 204 to 218 range at .050"
Old Feb 12, 2004 | 10:51 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
My combo isn't a lot different than your's. If you need to retain bottom end power and torque you will have to forego a really lumpy bumpstick. Just the way it is with a 305, and keeping some bottom end torque makes for a much more enjoyable daily driver anyway
So ... try a Crane PowerMax 260 or 266, or a Comp XE 256 or even the 262--which a few folks here really like.
Also, don't dismiss what F-Bird'88 has to say. He's a real guru, like RB83L69. Both have helped me a ton :hail:
Old Feb 13, 2004 | 10:14 AM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
not that it matters, but i just ordered the comp nx262 for my 85 305.
mine isn't a daily driver though. i've put >200 miles on it in the last 2 years.
Old Feb 14, 2004 | 07:31 PM
Duke901's Avatar
Car: 89 Formula
Any more info that will help me out?
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
