Fuseable Link
Old Feb 13, 2004 | 05:28 PM
ecuxc's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
Fuseable Link
HI I am looking to buy an 88 camaro convertible, it has an 86 corvette 350 tpi and the only thing it needs is a "Fuseable Link Coming Off The Starter Solenoid" Says that it shorted out since it was loose. Is this an easy fix. What exactly is the 'fusebale link'? Thanks
Old Feb 13, 2004 | 06:42 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Its function is similar to a fuse in the fuse block. It is a wire with a metal section in it that will melt when it gets too much amperage through it. It is an easy fix. You will see them on the small wires going to the starter solenoid.
Old Feb 13, 2004 | 06:57 PM
ecuxc's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
thanks
Appreciate it man
Old Feb 13, 2004 | 07:03 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
No problem!!!!!
Old Feb 13, 2004 | 09:34 PM
Flamingo's Avatar
Car: 89 GTA
Engine: 5.7 TPI
I had that one go out in my 86 IROC... nothing major to fix (taking you can get under the car and get your hands up by the starter LOL) and the piece was relatively inexpensive too.
Old Feb 14, 2004 | 11:53 AM
ecuxc's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
Ive been reading that fusible links, the wire is hard to come by, I looked for a part, only see an actual fuse. The fuse is the newer style, where can I get an actual wire, its a "16GA-rust" the haynes manual says.
Old Feb 14, 2004 | 11:57 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Go to any auto parts store and ask for a fusible link in 16 guage wire. It will come with a terminal lug on one end and you will have to splice it onto the old wire.
Old Feb 14, 2004 | 02:51 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
A fuseable link is nothing special. You dont need a specific part. You can use a wire two gauges smaller(larger number).
Fanatic1074
Oct 3, 2022 05:57 AM
3rd gen money
Oct 11, 2019 09:57 PM
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
SavingPvtEric
Sep 29, 2015 05:59 PM
