engine mounting.Which ones??
Old Feb 16, 2004 | 01:44 PM
powermite's Avatar
Car: Transam
Engine: ZZ4,Holley Stealth Ram,Commander 950
Ive been trying to buy new engine mounts for my 85Transam but with no luck.
My GM dealer here has sent me what he says are the correct ones for my car but they are nothing like mine.
Have a look at the pic and tell me which ones yours are like
thanks
PM
Old Feb 16, 2004 | 01:49 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Looks like the one bolted to your crossmember right now, or this:
http://www.partsamerica.com/PartDeta...ype=27&PTSet=A
Old Feb 16, 2004 | 02:33 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Your GM part# is 22188497. Assuming it's a V8. Your guy either looked it up wrong or it's mislabled.
Old Feb 16, 2004 | 02:42 PM
70GTO's Avatar
Car: 89 Iroc Z
Engine: Carburated 427 Smallblock
Transmission: 400 Turbo
Powermite,
It doesn't look like the ones that the GM dealer gave you are the right ones for a third gen. Heres a link to a post that might help. https://www.thirdgen.org/techbb2/sho...hreadid=223913
If you are willing to switch to a poly mount "energy suspension, etc...", they can be purchased from any aftermarket supplier "Jegs, Summit Etc...".
As far as the oem style rubber ones I'm not sure, but I don't think you'de have to get them thru GM, I'd think that they could be gotten thru Autozone, Advance Auto, Etc.....
Hope this helps, Bruce
Old Mar 13, 2004 | 11:51 AM
powermite's Avatar
Car: Transam
now these are the one they sent.Similar style but the holes dont line up.
The dealer tell me they are correct but i know otherwise,Why is there a slotted hole in the bottom whereas mine uses on of the outside holes,that arent even in the new mount.And even though the top two holes look right they dont line up with the holes on the crossmember
The make on the box is Anchor part#2387
PM
Old Mar 13, 2004 | 12:41 PM
powermite's Avatar
Car: Transam
I think i can answer my own question here.They are 2nd gen transam mounts.
PM
Old Mar 13, 2004 | 01:12 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
maybe he accidently typed in 75 instead of 85??
Old Mar 13, 2004 | 01:59 PM
powermite's Avatar
Car: Transam
well he must have terrible eyesight because the first pair he sent were 1st Gen
PM
Old Mar 21, 2004 | 05:55 PM
sittincamaro's Avatar
Engine: IVTEC 2.4L aka SBC
Transmission: auto
im in the process of doing my mounts as well. how the heck do you get them out? i dont have to take the spring out do i? ( theres no motor so the spring wont go back in if i take it out )
Old Mar 22, 2004 | 11:32 AM
five7kid's Avatar
Two choices:
1) Socket, u-joint, extension, ratchet, off-set box-end wrenches, lots of greasy dirt in eyes and up to your elbows, many colorful adjectives. If you've got really small hands, you might be able to get a regular combo box wrench on the nuts (one female member reported being able to do that a while back, even included a pic IIRC).
2) Using spring compressor, drop the a-arms at the bushings. Easy access to mount bolt nuts.
Old Mar 22, 2004 | 08:03 PM
Transmission: auto
::slaps on goggles and rubber gloves:: alright guys im going in.....
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
