How much power do you think I have??
Old Feb 2, 2001 | 12:04 AM
Dan87IROC-Z's Avatar
Okay, here's what I have: 87 IROC 350 TPI with: TES Headers, Hooker Cat-back, Gutted Cat with pipe inside, aceel cap, rotor, coil, wires, rapid fire plugs, K&Ns, brand new cloytes double roller timeing chain, ported plenum, lt4 hot cam, performance resource chip, no A/C, tb bypass, maf gut, air box gut, I think thats all, what kinds of hp/tq numbers am I looking at??
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Old Feb 2, 2001 | 10:00 AM
Dan91Z's Avatar
i'd say around 300 hp at the flywheel, and about 345 ft-lbs of torque..
My `91 Z28 Convertible
Old Feb 2, 2001 | 12:35 PM
LFN AT U's Avatar
Car: 2004 Chevy Avalanche
Engine: Some that run, some that don't
Transmission: 700R4's, a T-5, and a Turbo 350
I say Dan's about right. If anything, I'd guess a little less.
Old Feb 2, 2001 | 01:27 PM
84TransAm's Avatar
Heh, enough to school most ricers. But they only have like 40 hp?
--Steve S--
1984 Trans Am 305 LG4, 5 speed
RPO codes point to Recaro version
Daily Driver, Flowmaster 80 Series
Old Feb 2, 2001 | 04:53 PM
Some of those $100,000 ricers may have as much as 50 horsepower, LOL!
L98 TPI 350 (5.7L)
Old Feb 2, 2001 | 05:07 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
Someone here was making 285 rwhp and like 345 ft-lbs for rwtq w/ less mods, I see no reason why you'd be making less...
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
Old Feb 4, 2001 | 02:36 AM
burnoutrpm's Avatar
id say about 300-350hp! and about 35-375 lbs of tq at the flywheel! just a guess!!! good cam intake and fuel sytem! makes good hp!
1989 firebird formula
Mods: converted from T.B.I. to a carburator 305 to a 350. Flowmater exhaust,hedman shortie hedders,202 160 (882) heads,.447/.447 lift 222@.050 duration speed pro 327/350hp cam 350 .40 over (356) Edlebrock torker2 and a 600 edlebrock manual choke (1405)
Future mods performer rpm air gap intake (polished) comp roller cam, and way better headsa 400 defintely in the works!
Old Feb 5, 2001 | 02:44 AM
Wow!! 300+ would be great!!!!
L98 TPI 350 (5.7L)
Old Feb 5, 2001 | 02:57 AM
The ODB's Avatar
my guess is 290hp
and maybe just under 400 lbft of torque.
if you don't want to hop on a dyno to really find out just use a general equation to get you in the ballpark.
take your horsepower number and divide by your vehicles race weight (include driver)
example: 290/3500 = 0.082857
take the cube root of that = 0.435956
then multiply by the constant (234) = 102.0
the 102.0 would be your trap speed at the end of a quarter measured in miles per hour.
so all you have to do is weigh your car + your body weight and then make a few quarter mile passes at the track.
it is a simple formula and only used for ballpark figures.
have fun,
*I do custom performance mods on Edlebrock Performer carburetors (dualplane intake mods in the works),
White 1986 Irocz, 305/383 with Edlebrock Performer-RPM intake and Performer #1407 carburetor, +110hp shot of crack, 700R-4 tranny, 3.25:1 rear, Mcreary Road-Stars, SLP-stainless 1.75" shortie headers & Y-pipe, single 3" Borla exhaust, Linginfelter-TPI camshaft part number 74216 pulls 17" vacuum solid. Cam specs 213/219 @.050 114-LSA, .462/.470 lift @1.5:1 ratio. MSD-6AL, billet distributor, multi-retard, blaster-3 coil, and RPM switch.
N/A runs 10.9 @124,
Crack-runs 10.3 @135
haven't run at track since Oct-99
Old Feb 5, 2001 | 03:07 AM
Okay, that sounds easy enough, I am pretty good with math being an engineering student and all.
L98 TPI 350 (5.7L)
Old Feb 7, 2001 | 03:05 AM
zroc's Avatar
Car: 87 IROC
Engine: LB9 for the moment
to get that cam to realize its potential it needs to breath... look into some different heads and a high flow base and runners... otherwise that cam is not doing anything for you... with those items you could get better than .5 sec off the et, easy...
zroc
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
