Anybody use Flow Tech Headers?
Old Feb 4, 2001 | 02:09 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
Out of JC whitney? They are under $100 and have 1.5" primaries with 2.5" secondaries. I know you get what you pay for and I'd rather get some bigger and higher quality ones, but for 100 bucks wouldn't these be worlds better than stock tpi manifolds? Any and all input welcome. Thanks.
Base: 89 Iroc-Z LB9 auto 2.73 posi
Exh: 3" Dynomax muffler, 3" Pipe in place of cat
Ign: Accel 300+ wires, cap&rotor
Fuel: Cleaned and flow-matched injectors, afpr, !air pump&diverter valve
Sound: Clarion deck, Kicker speakers and amps
Suspension: KYB Shocks, BMR Strut Tower Brace
Misc: TB Bypass, Synthetic Oil, Flexlite Transmission cooler,
free mods, hopefully engine swap and 4th gen seats in the works...
Old Feb 4, 2001 | 02:53 PM
89ragtop's Avatar
Car: 1989 Camaro Convertible
I put them on my 305 that is in right now. They aren't too hard to install, I did 'em in my driveway at night with a 12 pack and a friend. The driver's side goes in easy enough, but the passenger side takes a little more time. I just ripped out my smog crap, so it only took a couple hours. The stock y-pipe can be made to work if you can weld. I got mine at a parts store for $79, so check around your area, they may be cheaper than Whitney. For the price they do the job. They are definitely a lot better than the stock manifolds. They already have a bung welded in for the 02 also. I can't think of a better mod for under $100.
Old Feb 4, 2001 | 03:00 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Thanks a lot man. I'm on my way to pick up some gear oil now and I think I'll see what Auto Zone has.
Old Feb 4, 2001 | 03:14 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Damn, not to shabby. Get some header wrap, and you will be good to go!
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Feb 5, 2001 | 03:00 PM
cica55's Avatar
yeah , I have those headers on my LG4, my previous best time as 16.8 , with the headers, cat-back & custom ram air I did 16.095. (still sucks, but .7 is pretty good).
PS: I know the car could have easily hit 15's , but it was just a bad day , I couldn't get anything right (shifting, traction and weather sucked too )
Old Feb 7, 2001 | 12:15 PM
rondubbs's Avatar
do the flowtech headers have the smog stuff?
Old Feb 7, 2001 | 12:54 PM
89ragtop's Avatar
You have to check. Don't quote me, but I believe you could get them with the AIR fittings for an extra $30-$40.
Old Feb 7, 2001 | 02:19 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Well these are 99 bucks and only have an O2 fitting. You can get them with air tubes for more money like he said. I'm just going to get some wrap and stage 8 bolts and see what those bad boys can do.
Old Feb 7, 2001 | 02:43 PM
84TransAm's Avatar
Does anyone know if the headers with the AIR holes are the same as the truck shorty headers also offered by Flowtech?
--Steve S--
1984 Trans Am 305 LG4, 5 speed
Daily Driver, Flowmaster 80 Series
BumpaD82
Feb 26, 2016 02:57 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
corey8084
Sep 17, 2015 02:56 PM
blackandblue02
Sep 10, 2015 08:19 PM
hdis2002
Sep 8, 2015 02:52 PM
