Whats the difference from LS1 to LS6?
Old Feb 22, 2004 | 12:58 AM
Catchen22's Avatar
Car: 91 Camaro T-Tops
Engine: 3.1L
What exactly is the difference between the LS1 and LS6????
Old Feb 22, 2004 | 01:32 AM
85TransAm406's Avatar
Car: 1985 Trans Am
intake and exhaust ports on heads, intake mainifold, cam, and on older ls1s, the ls6 block has slight differences to improve air circulation in the crankcase. A lot of newer ls1 cars have this block.
Old Feb 22, 2004 | 12:39 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
The LS6 heads also have a better configured combustion chamber. If you look at a pic of the two you can see the minor differences.
Main differences in the two though are the cams, the intake manifolds. The 2001+ LS1 motors had LS6 intakes though... Like already said they have differences in the blocks too to help w/ crankcase circulation...
Old Feb 24, 2004 | 02:06 PM
Catchen22's Avatar
Engine: 3.1L
So if they are the same size couldn't you fit an LS6 into an F-body if you can fit an LS1?
Old Feb 24, 2004 | 02:32 PM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
Exactly!! Same motor except for the internals, programming, & intake manifold, just like how everyone said above
Old Feb 24, 2004 | 03:41 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
GMMG actually did just that. Put LS6 motors in F-bodies... They called it the ZL1 Camaro... They also put C5R 427s in and labeled them Berger SSs and such...
Old Feb 24, 2004 | 06:59 PM
Car: 1985 Trans Am
I thought it was the other way around, with the 427s in the ZL1s, and hopped up 375HP ls1s in the SS (that's what it was in 2000, a hopped up ls1)
Old Feb 24, 2004 | 07:16 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
I was slightly wrong in my last post. There are 3 phases of ZL1 GMMG car. Phase 1 and Phase 2 are LS6 motors, and the Phase 3 ZL1 had a C5R 427.
Of the 69 ZL1s released I believe that 34 are 427 cars.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
BAMiller
Sep 14, 2015 06:38 PM
Formula_88AE
Sep 3, 2015 01:47 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
greenyone
Sep 2, 2015 03:39 PM
