won't start
Old Feb 23, 2004 | 09:29 PM
manofsorrow's Avatar
Car: '84 Firebird
Engine: 2.8L
Transmission: Automatic
won't start
Alright, I just bought my 84 firebird. When I first got the car, it would start no problem, but now only a few days later it wont start at all. When I turn the key I dont hear any noise at all. Please post suggestions.
Old Feb 23, 2004 | 09:31 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
battery, fusible link(s) could have blown. start checking the obvious, then work from there.
Old Feb 23, 2004 | 09:33 PM
Car: '84 Firebird
Engine: 2.8L
the headlights, horn, electronics and everything else is still working. I think ill try starting it with the battery from the grand am tomorow, maybe that will help.
Old Feb 23, 2004 | 10:21 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Before you do that, you should check to see if the application is correct. You dont want to blow out youre entire elec. system. Try jumping if you havent done so. The starter motor needs a lot of juice to run. Ive had it where the headlights, radio, etc etc all worked, but the starter wouldnt engage. much like the situation you described.
Old Feb 23, 2004 | 10:32 PM
walterrao's Avatar
Car: 91 RS
Engine: vortec 355 hsr
Transmission: wct5
Axle/Gears: bg3.27
go get a test light and see if theres power to the starter solonoid, then if not check for bad ground, then check the park switch to see if the power is getting there and coming from thyere, and so on
Old Feb 23, 2004 | 10:34 PM
walterrao's Avatar
Car: 91 RS
Transmission: wct5
Axle/Gears: bg3.27
never mind the checking for bad grounds part, ... im stupid
Old Feb 23, 2004 | 10:36 PM
Car: '84 Firebird
Engine: 2.8L
this just in... Im an idiot. The friend I bought the car off of came buy to hook up his deck so he could get his cd out. It turns out that the shifter has to be all the way forward to start. even if its in park but not all the way forward it wont start. I feel so dumb as this is my first automatic.
Old Feb 23, 2004 | 10:42 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Don't.............Think of it as a learning experience.
Old Mar 17, 2004 | 12:32 AM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Transmission: 700r4-slippin' on it's last leg
There should be an adjustment on your neutral safety switch (under the shifter) that will correct that problem. Remove the upper console and will be that neutral safety switch alongside the shifter. There should be 2 screws (can't remember size, but small). Loosen them up and slide switch back just a little.
Derick15
Sep 17, 2016 05:28 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
EFR2000
Aug 18, 2015 08:54 PM
