Can you run the L98 heads on a flat tippet cam 350?
I havean opertunity to pick some upfor almost free. I know the L98 had a roller cam. I didin't know if I could interchange the heads on my 350.
1983 Camaro Z28
Goodwrench 350ci V8, Edelbrock TES Headers, Flowmaster Catback, MSD 6al and Blaster 2 coil, Edelbrock Performer intake, (Edelbrock Performer 600cfm carb.)- went back to q-jet!!! T5, 373 rear, Eibach springs, Cervin Vega speakers, Rock. Fos. Sub, Pioneer CD,
email-chris4421@hotmail.com
"I used to be a Mustang Guy! I didn't know the power of the dark side!!"
1983 Camaro Z28
Car: 4
Engine: 6
Transmission: 5
Yes. The heads don't care about the cam. There may be other issues like making sure you use the right kind of rockers, but they'll work with either cam design.
ICON Motorsports
ICON Motorsports
Car: 89 Formula T-Top
Engine: 388 MiniramII
It was my understanding that the 85 and 86 L98 had a flat tappet cam from the factory.
'89 Formula 383 TPI
'89 Formula 383 TPI
Guest
Posts: n/a
Only thing you might run into is the bolt pattern, on 87-up the 4 center intake bolts are at a slightly different angle than earlier chevy engines, and I am pretty sure that includes the goodwrench motor you have. Its easily fixed but just making you aware.
The heads are off a '90 iroc. What kind of improvemant do you guys think I would get if I just bolted them on?
1983 Camaro Z28
1983 Camaro Z28
Guest
Posts: n/a
90 Camaro heads have the 4 differently aligned center intake bolts, so you will have to do a little work to your manifold so you can bolt it up. You will get a compression increase, and I would go ahead and clean up the bowls and port match the heads before you put them on. You will pick up about 1/2 point in compression with the head change, that should help out a little. That cam is pretty weak they put in those, so I'd look into some 1.6 rockers as well if you want a little more power out of it.
The heads you have now have bigger exhaust valves, but I'm not sure how much benefit that is on that engine, havent seen the heads before. The compression increase is probably going to help the most, followed by porting.
Thanks madmax
1983 Camaro Z28
1983 Camaro Z28
NinjaNife
Aug 23, 2015 11:49 AM
