timing chain replace?
Car: 89 formula
Engine: 383
Just changed cam,timing chain and gears,with both dots on the gears at the 12oclock position the engine should be at #1 firing position right?
89 350 TPI,edelbrock intake,SLP headers,highflo cats,flomaster cat back,accel 300+ ign,ported plenum and runners,ported maf,auto w/shiftkit,cold air induction,AFPR,Ed wright chip,3.23 posie best ET 14.01@98mph
You will be at tdc exhaust stroke with both dots at 12 o'clock. You need to move the cam gear 180 degrees to be at tdc intake stroke.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
E,
Actually, you can position the cam sprocket at either 6:00 or 12:00 when installing the timing set. Just move the crank to the #1 TDC position on the compression stroke when installing the distributor. I've always found it a little easier to aling the marks in the 6:00 / 12:00 positions because the marks are closer together.
Later,
Vader
"No matter how hard you try you can't stop us now..."
Adobe Acrobat Reader 4.0
Later,
Vader
i install gear and the chain like vader said. crank gear dot at 12:00 cam gear dot at 6:00, or dot to dot. i too find it easier to line them up if they're dot to dot. after i have the gears and chain on and bolted up i spin the engine untill i have the crank gear at 12:00 and the cam gear at 12:00, or both dots straight up. at this point you can install the distributor with the rotor pointing toi the #1 post on the cap.
ICON Motorsports
1st & 3rd
ICON Motorsports
1st & 3rd
NBrehm
Aug 25, 2015 11:49 PM
