What centerbolt valve covers clear comp promag rockers?
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
will a stock type valve cover clear comp promagnum RR's? or do I need a taller style or maybe moroso sheet metal ones.
keep in mind I would like to keep the stock pcv system.
I did look through summit but I was hoping someone here was using these rockers with centerbolt heads and could just say "I use them with stock vc's"
thanks
thanks
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
That's odd, I'm using the Pro Magnum 1.52 rr's on my set of stock L98 heads with some stock GM valve covers off a set of Vortec heads, which I assume are the same as the earlier centerbolt valve covers like what you are probably trying to use. I did have to cut out the supports inside the valve covers, though... only on one side if I remember correctly. Took a whizzer to it, 20 minutes later they fit and I've been running them for 5k miles with no probs.
Car: 91Z28 L98
Engine: HSR 350
yup, didn't touch the baffles. The supports looked kind of like a triangle, and I just cut one of the sides of all of the triangular supports.
Car: 91Z28 L98
Engine: HSR 350
If this was the triangular support inside the valve cover, cut out only the red part on each support to make them fit. Oh yea, make sure you cut out the correct side.... on one of mine, I cut out the wrong side and had to go back and cut out the other too. But I still don't have any problems with them leaking, so don't worry too much about that.
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
You can take and bend the baffles and make them work. Right at the bottom of the baffle where the rocker would hit, bent he stamped part straight down and they should clear w/o hitting. I have seen that done on about half dozen sets of VCs w/ promags w/ no problems.
Car: 92 Z/28 clone
Engine: 383 carbed
Transmission: t-5
i'm using the comp promag rockers myself....1.6 ratio and they clear my chrome valve covers.same hieght as stock...i had to cut the brace to clear the guide plates though
MoJoe
Sep 24, 2015 09:12 PM
